14b compressor on a wrx turbo
Old Apr 10, 2005 | 08:43 AM
sporty240's Avatar
Default 14b compressor on a wrx turbo
Hey is it possible put a 14b compressor housing and wheel on a TD04L -13G(WRX turbo)? Will it bolt on or is it more trouble than its worth?
Old Apr 11, 2005 | 10:06 AM
sporty240's Avatar
Default Re: 14b compressor on a wrx turbo (sporty240)
ttt
Old Apr 11, 2005 | 12:40 PM
JalopySiR's Avatar
I asked that same question a while back, as I wanted something easy, that wouldn't require too much management. The short answer ended up being, No. It would require machining, a new shaft, and too much effort for the return. If you have a WRX, you should talk to Deadbolt turbo, on NASIOC.
HTH
Old Apr 12, 2005 | 01:40 AM
sporty240's Avatar
Default Re: 14b compressor on a wrx turbo (JalopySiR)
why would it need a new shaft will the wheel not fit is the mounting hole to small or too big?
Old Apr 12, 2005 | 07:44 AM
GPNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 &raquo;</TD></TR><TR><TD CLASS="quote">Hey is it possible put a 14b compressor housing and wheel on a TD04L -13G(WRX turbo)? Will it bolt on or is it more trouble than its worth?</TD></TR></TABLE>
It is a lot of trouble and not at all worth it. The compressor cover of a td04 is not the same as that of a td05. The wheels and shafts are also sized diffently so it will require expensive machining. You would be better off getting a new turbo or a new cartridge
Old Apr 12, 2005 | 08:07 AM
Bailhatch's Avatar
Default Re: 14b compressor on a wrx turbo (GPNY)
more importantly isnt that turbine just tiny? I would never (again) put anything smaller than std T3 turbine on any honda engine.
Old Apr 12, 2005 | 08:15 AM
YiNYaNg's Avatar
Default Re: 14b compressor on a wrx turbo (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">more importantly isnt that turbine just tiny? I would never (again) put anything smaller than std T3 turbine on any honda engine.</TD></TR></TABLE>
I like my 14b since it has fast spool up and it's good as daliy car..very good 2000rpm- 6700rpm power....
Phillybiker
Nov 4, 2012 07:57 AM
wpgcivic
Apr 21, 2006 06:10 PM
scttydb411
Mar 24, 2004 10:09 PM
seanjohn81
Jul 8, 2003 01:00 PM
Aeka GSR
Apr 11, 2003 02:43 PM
