What do you think is bent?
Old Apr 10, 2005 | 08:22 AM
essex's Avatar
Default What do you think is bent?
The right front wheel seems pushed back more than the left. Control arm? Knuckle?
Modified by essex at 4:36 AM 9/17/2006
Old Apr 10, 2005 | 08:28 AM
90civichbsi's Avatar
Default Re: What do you think is bent? (essex)
probably just bad crossmember bushings
Old Apr 10, 2005 | 08:48 AM
slowpokesi's Avatar
Default Re: What do you think is bent? (90civichbsi)
i could be the lower / upper control arms,
id check the simple stuff like bushings first.
those tires are rediculous.
Old Apr 10, 2005 | 09:16 AM
2kTeg's Avatar
Default Re: What do you think is bent? (slowpokesi)
my car looked just like that, i hit a curb and it bent the place racing cross member and the radious rod.
Old Apr 10, 2005 | 09:24 AM
bagpipe goatee's Avatar
things it could be, from likely to unlikely
misplaced bushings, most likely in radius rod
front crossmember
lower or upper control arm
rear crossmember
steering knuckle
frame damage
thats not to say theres not other things wrong, such as being like that will probably blow out the bushings on the lower control arm, but those things are the likely causes.
Old Apr 10, 2005 | 10:51 AM
JokerTypeR's Avatar
Default Re: (bagpipe goatee)
I hit a curb and pushed mine back. How'd I fix it? Hit another curb on the other side, HOWEVER! If you want your car to run normal try to fix one problem instead of creating a reversing-problem.
By the way, this thread will come in handy when I try to fix mine...if I do.
Old Apr 10, 2005 | 11:31 AM
90JPRCRX's Avatar
Smells like Tuna
you also have an interesting lugnut situation myfriend
Old Apr 10, 2005 | 01:24 PM
DocSean's Avatar
Get an adjustable traction bar setup: fix that caster and upgrade all-in-one.
Old Apr 10, 2005 | 02:07 PM
doublethink's Avatar
Default Re: (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">Get an adjustable traction bar setup: fix that caster and upgrade all-in-one.</TD></TR></TABLE>
Old May 23, 2005 | 08:14 AM
Full-Race Geoff's Avatar
the lower control arm and the crossmember/radius rod are probably both damaged.
If you use a high quality aftermarket crossmember, and get a new lower control arm you shoul dbe all set! ALso dont forget to get an alignment
Old May 23, 2005 | 09:41 AM
turbohappy's Avatar
Default Re: What do you think is bent? (88JPRCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88JPRCRX &raquo;</TD></TR><TR><TD CLASS="quote">you also have an interesting lugnut situation myfriend</TD></TR></TABLE>
I was noticing that as well. Surely you don't drive like that?
corpsebesideme
11
Aug 21, 2016 01:11 AM
94vtirozguy
Apr 14, 2006 11:37 PM
Aznboy031
Sep 11, 2005 11:12 PM
thomst4R
Suspension & Brakes
Jul 17, 2005 06:20 PM
skyliner186
11
Dec 29, 2003 08:39 PM
