how to find out if a valve is bent? (valve out of motor)
Old Apr 10, 2005 | 06:35 AM
SkRiBLaH's Avatar
Default how to find out if a valve is bent? (valve out of motor)
ive slid them all in the guides and they all go in ..
so how else can i find out if a valve is bent?
also does anyone know if autozone/advanced has a valve spring compressor thats compatible with b type motors?
Old Apr 10, 2005 | 08:41 AM
JDMotive's Avatar
Default Re: how to find out if a valve is bent? (SkRiBLaH)
I usually put the stem in a electric drill and spin it.
Old Apr 10, 2005 | 12:53 PM
SkRiBLaH's Avatar
Default Re: how to find out if a valve is bent? (JDMotive)
good idea. any others/
Old Apr 10, 2005 | 01:31 PM
asubennett's Avatar
Put some color substance on the valve before you spin it. That will show you the bend in terms of how the substance is distributed.
Old Apr 10, 2005 | 06:36 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">I usually put the stem in a electric drill and spin it.</TD></TR></TABLE>
i tried doing this with my bent valves, It wasnt very accurate for me....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Put some color substance on the valve before you spin it. That will show you the bend in terms of how the substance is distributed. </TD></TR></TABLE>
i should have done this...
Old Apr 11, 2005 | 07:50 AM
asubennett's Avatar
Default Re: how to find out if a valve is bent? (1.6i)
A thick colored ink works well.
Old Apr 11, 2005 | 11:55 AM
boosted k20's Avatar
with the head off, u will need to get a C-Clamp style spring compressor for the valve springs. or just go out and get the snap-on universal spring compressor tool. i find it much easier to use the C-Clamp style spring compressor when the heads off the car
Old Apr 11, 2005 | 12:09 PM
marcin's Avatar
Default Re: how to find out if a valve is bent? (boosted k20)
roll the valve on a FLAT surface. you should see it.
also when you put a cut on the valve you would hear it. would oscilate
m.
Old Apr 11, 2005 | 01:20 PM
hitvtecgetloud09's Avatar
proj21
Oct 1, 2009 02:40 PM
BLacK FirE
May 24, 2006 05:30 PM
95blackEG
Apr 25, 2006 10:28 PM
Shift_Fast
Feb 19, 2005 11:24 AM
BLK99VTECR
Mar 1, 2004 05:13 AM
