Alignment ques.
For the Ek is the rear camber adjustable? Cuz i dnt wnt to waste $$$ on 4 wheel alignmnt , if the rear are not adjustable. (no camber kit installed)
Thanx in advance for the answer
the rear camber is adjustable if you get a camber kit or put washers on that upper control arm. Regardless, you should get a 4-wheel alignment after a lowering. I've seen the difference it makes.
