distributor alignment?
so i got a dizzy for my mini me, i line it up but for some reason it doestn want to go in allthe way. also, i noticed when (if) i get it in, the holes to bolt it in have extra area so u can turn the dizzy. how am i supposed to align it ?
The slot on the distributor is keyed so it will only go in to the cam one way, this prevents people from installing it 180 deg out. The extra room in the slots that your talking about is to adjust the ignition timing, you do this with a timing light. Jump the service connector located beneth the dash on the passenger side, then start the car let it warm up, and move the distributor so the red line between the two white lines lines up perfectly with the mark on the timing cover. Then snug one of the bolts holding the distributor on and verify that it didn't move. Snug the rest and your on your way.
z7rix
Oct 9, 2013 10:56 AM
melissashelton1
Feb 4, 2010 05:16 PM
