coolant in oil but good compresstion
Old Apr 9, 2005 | 04:03 PM
mbdelsol's Avatar
Default coolant in oil but good compresstion
compresstion came out good across the board. when i drive the overflow tank get full. Car never overheat when i open the radiator it empty.
b16a
aebs sleeves
je pistons 9:1
eagle rods
cosmetic head gasket
arp studs
compresstion test 170 across the board
filled the radiator up drove it around and radiator was empty. reserve was full and look light brown. drain the oil and had like 5 qt very milky
Old Apr 9, 2005 | 04:55 PM
beepy's Avatar
Default Re: coolant in oil but good compresstion (mbdelsol)
cosmetic head gasket is much very bad. Need must replace with OEM.
Old Apr 9, 2005 | 04:59 PM
mbdelsol's Avatar
Default Re: coolant in oil but good compresstion (beepy)
is it possible to have bad head gasket with good compression
Old Apr 9, 2005 | 05:40 PM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbdelsol &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to have bad head gasket with good compression</TD></TR></TABLE>
Sure, I did and didn't even know it until I pulled the head and the #2 piston was steam cleaned.
I didn't even have coolant in the oil.
Compression tested at 170-175 all the way across, the motor had several bearings that were in very poor shape, 3 pistons with the top ring land broken, and a blown head gasket between #2 & #3 cylinders.
Old Apr 9, 2005 | 07:21 PM
speedworks's Avatar
Default Re: coolant in oil but good compresstion (96-EJ6 B18C)
more than likely it is a bad head gasket.
Old Apr 9, 2005 | 07:25 PM
Jared's Avatar
factory head gaskets
Old Apr 9, 2005 | 09:23 PM
EJ1 wilcox's Avatar
Default Re: coolant in oil but good compresstion (Jared)
My car is doing the same thing... my overflow tank fills up but my car doesn't over heat...
I'm going to have to replace the headgasket soon
Old Apr 10, 2005 | 04:31 AM
NJIN BUILDR's Avatar
Leaking between sleeves and block.This won't show any change in compression or leakdown.
Glenn
Old Apr 11, 2005 | 05:12 AM
mbdelsol's Avatar
Default Re: coolant in oil but good compresstion (NJIN BUILDR)
any way i can test if it the headgasket or sleeves??
Old Apr 11, 2005 | 05:17 AM
RyanEJ8's Avatar
I just pulled my head to replace the headgasket. Compression and leakdown test were fine.
Old Apr 11, 2005 | 08:50 AM
EJ1 wilcox's Avatar
Default Re: (RyanCivic2000)
Question: My overflow tank is filling up about an inch every day I drive my car (just pour it back into the radiator)... my car has never overheated...
This is obviously a symptom of a head gasket issue...
? How long do I have before there is a real problem? Or, is the over flow tank filling up enough of a reason to change the head gasket?
Should I wait until my car over heats? Or, should I pick up a new HG, some ARPs, and install them ASAP?
**Sorry for hijacking the thread. I just don't want to start yet another SOHC head gasket thread with a simple question **
Old Apr 11, 2005 | 11:14 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Leaking between sleeves and block.This won't show any change in compression or leakdown.
Glenn</TD></TR></TABLE>
this would be my vote,
Old Apr 11, 2005 | 04:43 PM
Antilag's Avatar
Default Re: coolant in oil but good compresstion (prelittlelude)
Sounds like when you boost the head is lifting and causing the problem. Maybe from stretching head bolts or the block deck itself. Do a leak down test if it passes then pull the head and replace to head studs and check the block deck with a straightedge.
Old Apr 12, 2005 | 04:21 PM
mbdelsol's Avatar
pull the head off today. cylinder number 1 is full of water the rest seem dry. would that be cause by blown headgasket
Old Apr 12, 2005 | 08:49 PM
Antilag's Avatar
yes check the deck w/ a straigtedge lay it across and diagonal if you can slide .002 or bigger of a feeler guage under the straightedge, then it needs to be decked, otherwise if its fine then get headstuds. goodluck
Old Apr 12, 2005 | 09:40 PM
kleefton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbdelsol &raquo;</TD></TR><TR><TD CLASS="quote">pull the head off today. cylinder number 1 is full of water the rest seem dry. would that be cause by blown headgasket</TD></TR></TABLE>
Ouch. Make sure your cylinder 1 sleeve is not cracked. Hopefully you did not go WOT while you had that problem.
To be honest with you though, I think you've done some damage, especially if you were driving around like that for a while. You must have a lot of coolant in your oil too.
Old Apr 12, 2005 | 09:48 PM
Tony the Tiger's Avatar
Default Re: coolant in oil but good compresstion (kleefton)
Don't keep driving with a bad headgasket... Sometimes the oil might be okay, but coolant must be entering the engine during combustions and can really mess up the rings.
Plus what's the point of driving the car if you cannot even rev it? A developing bacd headgasket is like a timebomb and it would suck if a huge air pocket gets inside the cylinder head while doing a 4th gear pull Not good at all.
After all this time, I only trust OEM Honda headgaskets
Old Apr 12, 2005 | 10:19 PM
mbdelsol's Avatar
Default Re: coolant in oil but good compresstion (Tony the Tiger)
i have only driven the car for about 5 miles. I never rev it past 3,000 sense my car not tune yet. from visual inspection the sleeves look good.
Old Apr 13, 2005 | 05:52 AM
RyanEJ8's Avatar
Default Re: coolant in oil but good compresstion (9sech22civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic &raquo;</TD></TR><TR><TD CLASS="quote">yes check the deck w/ a straigtedge lay it across and diagonal if you can slide .002 or bigger of a feeler guage under the straightedge, then it needs to be decked, otherwise if its fine then get headstuds. goodluck </TD></TR></TABLE>
Only problem with this is that you need a damn good straightedge. I tried checking mine with a straight edge when I changed the headgasket this past weekend and I kept getting inconsistent readings. I blamed this on the straight edge.
Old Apr 13, 2005 | 01:06 PM
Antilag's Avatar
Default Re: coolant in oil but good compresstion (RyanCivic2000)
your pistons were all in the middle and not at tdc when you did the measuring right?
niceprelude
Dec 21, 2014 08:05 PM
iceman7329
25
May 22, 2007 07:24 AM
mbdelsol
Apr 11, 2005 07:13 AM
mingbling96
Jan 17, 2005 09:31 PM
geldingmakr
16
Aug 4, 2004 01:28 PM
