skunk2 cams with a chipped ecu????
Can you run skunk2 stage 2 cams with a chipped Ecu it is the spoon program
9600 rev limit. I just need to know if I can run the two together or not.
Any help would be great...
all those programs you see around spoon...mugen...pyr...feels...j's...etc etc etc....are a joke...just slightly moded stock maps...meant for basicly stock motor with a few bolt ons....since you already have a chiped ecu just get crome or hondata or uberdata and have it tuned properly....
B16 Portflow ported and polished head, spring, retainers, ferreti valves, SOON skunk2 cams, intake, dc header, exhaust, chipped spoon program p30 ecu.
you need it tuned properly for that setup....to much fuel and youll wash the cylinder walls and the pistons will never seal properly...not enough fuel and pistons expand and destroy themselves and take the cylinder walls with them....
i think it is more likley that that hell blow some holes in the tops of the pistons from detonation berfore the pistons would expand and take out the walls. And i am also not too sure about running rich and having the pistons not seal properly...
the mugen program sux!! details of it
lowered vtec to 5400
rev limit 9900
Ignition advanced 2 degree's through out the low cam.
ignition advanced 1 degree in high cam
AFR: 11.81 at idle
average AFR 12.3 cruising
WOT AFR 12.1
it can be a good program to start with. and little by little by using crome start taking away more and more fuel until you are satisfied with the AFR
rev limit 9900
AFR: 11.81 at idle
WOT AFR 12.1
I have a stock 1.8 ls head with 60000 miles for sale if intrested IM me
Also a stock b16 intake manifold
b16 injectors obd0 and fuel rail.
Brand New ARP MAIN STUD kit for a b16.
1.8 LS ECU unchipped.
2 B16 IAC valves obd1 and obd0
LS water pump with less than 8000 miles on it.
92-95 civic 2 door side skirts wings west poly
Best offer on all parts just IM me
Will also consider trades
Looking for cam gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkwidow420 »</TD></TR><TR><TD CLASS="quote">any more input </TD></TR></TABLE>
sure... don't skimp... If you can't afford Hondata, then they Uberdata and get it tuned.
