Is this possible?
Old Apr 9, 2005 | 01:09 PM
zman's Avatar
Default Is this possible?
The place who did my b16 swap into my 95 civic didn't use the proper rear mount so one of the bolt holes didn't line up. Now i have a big chunk of my tranny casing missing and the shop says they aren't going to do anything about it.
I was wondering if i could just get another casing. I've sourced one but i need to know if its possible and whats involved.
Heres a pic of the damage:
Old Apr 9, 2005 | 04:45 PM
projectTeG's Avatar
from that pic it looks like your missing the 2 lower bolts the the bracket
Old Apr 9, 2005 | 04:58 PM
zman's Avatar
Default Re: (projectTeG)
from that pic you can clearly tell that the wrong mount is being used. I've already picked up a 94-01 integra rear mount.
Old Apr 9, 2005 | 07:50 PM
mmuller's Avatar
Mad Scientist
Default Re: Is this possible? (zman)
weld and re-tap
Old Apr 9, 2005 | 08:15 PM
zman's Avatar
Default Re: Is this possible? (mmuller)
really? I was just going to replace the clutch housing. Are all b-series hydro clutch housings the same?
I found a gsr one but i have a b16.
Old Apr 9, 2005 | 08:16 PM
zman's Avatar
is the busted part a part of the clutch housing (bellhousing)?
Old Apr 9, 2005 | 08:25 PM
my93hatch's Avatar
i'm with muller on this....i did it to a quad i owned and it held-up just fine...the chain fell off and ripped the front sprocket out and i had it welded and put the sprocket back on and never had a problem with the weld...and that drove the quad....i know it's a little different than a car but just some food for thought
Old Apr 9, 2005 | 08:40 PM
zman's Avatar
Default Re: (my93hatch)
well is the bolt hole that busted in the picture of my busted tranny the same as this one in the picture?
If so, then changing the housing will require removal of the gearsets, diff, pretty much everything right?
Old Apr 10, 2005 | 07:11 AM
projectTeG's Avatar
Default Re: (zman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zman &raquo;</TD></TR><TR><TD CLASS="quote">well is the bolt hole that busted in the picture of my busted tranny the same as this one in the picture?
If so, then changing the housing will require removal of the gearsets, diff, pretty much everything right?</TD></TR></TABLE>
thats not the same side of the tranny thats in the first pics^^^^these pics are the front the first pics are the back....itll be easier to just weld and retap
Old Apr 10, 2005 | 03:48 PM
zman's Avatar
where would i go to get it welded? Any welding place?
Old Apr 10, 2005 | 09:13 PM
PrettyLude's Avatar
a place that can weld aluminum
Old Apr 10, 2005 | 11:33 PM
_Cyclone_'s Avatar
Default Re: (zman)
Most places that specialize in welding can weld aluminum... alot of performance shops weld aluminum as well.
SiRCiviC94
Mar 9, 2013 07:31 AM
Honteggie
Aug 24, 2006 07:43 PM
bleedblue94
Apr 3, 2006 11:09 AM
thedon833
Nov 25, 2002 10:15 AM
Mike B
Jun 10, 2002 06:39 PM
