Any1 here have an AEM pressure regulator?
Old Apr 9, 2005 | 01:02 PM
thirdrail-211's Avatar
Default Any1 here have an AEM pressure regulator?
Can you tell me how to tune it? Which way do you turn the valve, and what will it do?
Old Apr 10, 2005 | 06:04 PM
iam7head's Avatar
Default Re: Any1 here have an AEM pressure regulator? (thirdrail-211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thirdrail-211 &raquo;</TD></TR><TR><TD CLASS="quote">Can you tell me how to tune it? Which way do you turn the valve, and what will it do?</TD></TR></TABLE>
there's a valve you can turn probably with a long nose piler, the tighter you turn, the higher the pressure.
and what will it do? it lesser or rise the fuel pressure,
why would i want to do with that? turbo, high compression na, etc
Old Apr 11, 2005 | 09:02 AM
m0t0rhead's Avatar
Did you already install it ?
What you should have done was install a B&M fuel pressure gauge first.. checked what your stock pressure was.. then install the regulator and set it about 5 psi more than stock.
Realistically.. on an accord, you don't really need much more fuel pressure being that it probably isn't heavily modified. Buying an AEM regulator for $200 wasn't really the best way to spend your money. But, that is a whole other issue
You're fuel curve will be rich in some areas and leaner in others. Since you're looking to extract as much performance as possible out of your F22, i would recommend getting a piggy back fuel computer and some dyno time to lean out those rich areas and add more fuel to where it needs it. You can pick one up for about 200-350$. Good luck.
eg:R
Dec 31, 2011 11:42 AM
f2rider
Dec 8, 2004 05:24 PM
Wuman
Dec 8, 2004 08:42 AM
bigstatik
Jun 13, 2004 02:58 PM
Malice
Mar 31, 2002 04:48 PM
