Can you cut your wastegate spring
Old Apr 9, 2005 | 06:24 AM
ATgrills.com's Avatar
Default Can you cut your wastegate spring
I installed the ssautochrome set up on a customers b20vtec,,,
everything is perfect and runs great...
however the wategate that came with the kit must have some crazy spring in it since I believe its set somewhere arround 25PSi.... I floor the car for one second and it gets to 15PSI.....
I have the wastegate unhooked on the top and the side nipple goes to vacum on the intake....
Is there any way I can cut the spring???
has anyone ealse had this problem with the ssautochrome tial style wastegate???
thanks
Tyler
Old Apr 9, 2005 | 06:36 AM
93turbo16's Avatar
I had this problem, and even with a 7psi spring chopped down (to put it around 4 psi) we still got spiking. WE had to cut the wastegate flange off, and actually dremel out the whole and pipe for the wastegate. Then put it back on and rewelded it and it was perfect. The reason we cut the spring is because there are two greens, and we thought we got the wrong spring. BUt it was actually the stupid wastegate placement/hole.
Old Apr 9, 2005 | 06:39 AM
Default Re: (93turbo16)
well is the new style manifold,,, not their old one,,, and I did port out the wastegate whole because they didnt weld it perfectly centered!
so can I try cutting it??
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Can you cut your wastegate spring (ATgrills.com)
put the side nipple to the compressor as it will see pressure before the intake will.
Old Apr 9, 2005 | 06:46 AM
Default Re: Can you cut your wastegate spring (boostedcivicsir)
there is no nipple on his turbo!
Old Apr 9, 2005 | 06:50 AM
Mr. Badwrench
drill and tap a 1/8 npt
thats what i do on all mine.
Old Apr 9, 2005 | 07:04 AM
93turbo16's Avatar
you can cut it, if you want to. WE did and it works fine.
Zeusfire69
Apr 19, 2007 01:55 PM
saxqtzk
Oct 1, 2006 08:32 PM
komat
May 13, 2006 07:15 PM
RNPoo7
Apr 6, 2005 04:20 PM
