crank pully tight?
Old Apr 8, 2005 | 09:27 PM
balbowskie187's Avatar
Default crank pully tight?
h23a1 engine i had a stock crank pully with a hex shape in it for a holder tool. my new aftermaket pully does not have that shape in it for the tool, how do i get the pully tight again? since i gota tighten it to such a heavy ft pd????
Old Apr 8, 2005 | 09:42 PM
95lude-s's Avatar
Default Re: crank pully tight? (balbowskie187)
there should be a access cover(rubber piece) on the trans take that off and you'll see the flywheel and just jam a screwdriver in there and tighten the **** to specs thats what i did still seems fine
Old Apr 9, 2005 | 10:06 PM
MackDad's Avatar
Default Re: crank pully tight? (95lude-s)
That's not a good idea as you can break teeth off the flywheel....
If I were you i'd take it to a shop and have them tighten it with an impact gun...They have special extensions that are rated at a given torque....
Old Apr 10, 2005 | 09:02 PM
i have a high tq. impact gun and a 150 lb tq. stick (the extion you refer to). i need to know the best way to get the bolt tight. the screw driver deal sounds risky but its the best thing i could think of too.
Old Apr 11, 2005 | 10:21 AM
flyrod's Avatar
there are several good threads on this, maybe even in the FAQ.
david90
Aug 12, 2009 05:51 PM
HondAcura
Dec 24, 2005 05:24 AM
PinkMaggit
16
Oct 21, 2005 09:03 AM
LudeyKrus
Jan 3, 2004 05:56 PM
altoid
Jun 27, 2003 12:34 AM
