Thermostat install gone bad, bolt broke and got stuck
Old Apr 8, 2005 | 07:07 PM
so simple's Avatar
Default Thermostat install gone bad, bolt broke and got stuck
92 Prelude Si.
Removed the old thermostat, put the new one in. Screwed 1 bolt in, everything fine. Then screwing in the other bolt, once it reaches the end of the head and i spin for one final little torque, bolt snaps in 2. So half of the bolt is stuck in (the housing?). With such a difficult angle, it was hard to try to take the bolt out. I used a drill w/ a skeudriver and craftsman bolt out, didnt work. Tried to drill a screw into it but the bolt was snapped in half at an angle so it was really hard to get anything to go straight onto the bolt. Tried the bolt out again at an angle, missed the screw, it put a hole right next to it. The bolt looks like it got heated up and is a part of the housing now.
I gave up, went and bought some red hi-temp rtv silicone gasket stuff and jb weld. I screwed the 1 good screw in, then put the silicone around the thermostat housing. Gonna wait til the morning to see if it dries, will the rtv hi-temp silicone be strong enough to hold the other end of the housing together while at the same time seal it? Maybe put some jb weld on it after the rtv dries as an insurance? will it withstand the temps? the rtv is 650 deg F, JB Weld 600 deg F.
sigh, cars giving me a headache. once this problem is fixed this things going for sale.
Old Apr 8, 2005 | 09:48 PM
jackstands's Avatar
Default Re: Thermostat install gone bad, bolt broke and got stuck (so simple)
It won't hold. You might want to just pull the whole housing off the water pipe so you can get a better look at it.
Old Apr 8, 2005 | 10:45 PM
so simple's Avatar
how much would a shop charge to get out a bolt in that difficult of a location?
Old Apr 9, 2005 | 08:51 AM
LudeyKrus's Avatar
it might hold for a bit, but there's no way in hell I would trust just silicone.
If it's what I'm thinking about, just pull the water neck off the head and then you can deal with the bolt however you want. You're making it hard on yourself by leaving the water neck on the engine.
Old Apr 9, 2005 | 10:02 AM
951dc5's Avatar
Default Re: (LudeyKrus)
ha just ditch it and sell it..just like mine..as soon as i put in a used tranny
Old Apr 9, 2005 | 10:21 AM
LudeyKrus's Avatar
Default Re: (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">ha just ditch it and sell it..just like mine..as soon as i put in a used tranny</TD></TR></TABLE>
Over a snapped bolt..... what a moron
Old Apr 9, 2005 | 11:16 PM
so simple's Avatar
got that 'water neck' off the head, it looks pretty bad, think ill get a new one. does anybody know what its technically called? is it "Connecting pipe, part 19505-P14-A00 under the thermostat section? its about like $37 or so on the slhonda website if thats the right part. ill try to get a picture up soon, i took one but 56k is slow
Old Apr 10, 2005 | 12:04 PM
so simple's Avatar
okay looked at the parts diagram picture on slhondaparts.com and looks like its a 'thermostat case' part 19320-pt3-a00 for $36.09.
oh yeah when i took out the old one, on the part that connects to a large hose on the bottom, there was some red silicone, so i guess somebody fixed it before or that is required because that hose goes inside instead of 'over' w/ a tbolt. since i guess you cant use a tbolt when the hose goes inside
Old Apr 10, 2005 | 11:30 PM
PrettyLude's Avatar
i have another one if you want it pm me
DCRB
13
Mar 23, 2010 09:47 AM
spidermancivic
Aug 11, 2007 08:17 AM
HCivicSi23
Jul 14, 2007 11:15 PM
is3oo
Oct 4, 2003 01:48 PM
fe519
Jun 19, 2003 05:36 PM
