crank was rotated wrong!!!!!!!!!
Old Apr 8, 2005 | 06:52 PM
vangc6780's Avatar
Default crank was rotated wrong!!!!!!!!!
i rotated my crankshaft clockwise instead of counterclock wise........
is there going to be any serious damage done to it????????
Old Apr 8, 2005 | 06:53 PM
vangc6780's Avatar
Default Re: crank was rotated wrong!!!!!!!!! (vangc6780)
any1????
Old Apr 8, 2005 | 10:35 PM
zacdaddy77's Avatar
I'd like to know also ( my guess is no)
Old Apr 8, 2005 | 10:48 PM
R91Si's Avatar
no
Old Apr 8, 2005 | 10:49 PM
rjay8604's Avatar
Default Re: crank was rotated wrong!!!!!!!!! (zacdaddy77)
you're fine. Don't worry. The engine will not be harmed.
The only potential problem is your putting slack on the timing belt the worng way, and it could make the belt skip a tooth, but that won't happen when you turn it by hand, it is too slow.
Old Apr 9, 2005 | 02:46 PM
vangc6780's Avatar
Default Re: crank was rotated wrong!!!!!!!!! (rjay8604)
thank you all for the info
Old Apr 11, 2005 | 04:03 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">The only potential problem is your putting slack on the timing belt the worng way, and it could make the belt skip a tooth, but that won't happen when you turn it by hand, it is too slow.</TD></TR></TABLE>It can still happen, but not always. It sure can't hurt to check whether your cam timing has skipped or whether the belt tension is OK.
Mishako129
Sep 4, 2012 10:14 PM
paowa
Feb 8, 2009 04:20 PM
babykay
Feb 17, 2008 03:49 PM
Ag3nt_Orang3
Jan 28, 2006 11:36 AM
1SlowSi
Feb 6, 2005 04:39 PM
