Please help with SOHC supercharger install question!
I just finished installing a Jackson supercharger on my D16y7, but the car idles like crap! The idle jumps between 1,500 and 3,000 and back. It sounds like if I have a huge *** race cam or something! The IAC is hooked up and everything, however, do the hoses to the IAC need to be connected a certain way, or can you just run any coolant lines to it? Another thing, I couldnt take off my crank pulley, and since the JR pulley is exactly the same, I just left my stock one. Would that make any difference? I mean, why would you have to change the crank pulley if they are the same size?
thanks in advance,
Alex
thanks in advance,
Alex
basically it sounds like u have a vacuum leak,
I had a problem when I first put mine on, it was sitting on top of the alternator,
so when torqued the IM down it didnt seal properly leaving a vacuum leak.
is the FIT valve the same as the IAC? I checked for vaccum leaks with butane from a lighter but couldnt find any.. Could the PCV valve be leaking from the grommet or something? Thanks for all your replies..
I was told that i have the wrong throttle body, so I bought an 98 EX throttle body and IACV, but the car runs worse, because my DX has a 3 wire IAC and the EX has a 2 wire IAC.. What should I do?
........when you gonna go to the track again?
