Please help with SOHC supercharger install question!
Old Apr 8, 2005 | 11:05 AM
streetrage's Avatar
Default Please help with SOHC supercharger install question!
I just finished installing a Jackson supercharger on my D16y7, but the car idles like crap! The idle jumps between 1,500 and 3,000 and back. It sounds like if I have a huge *** race cam or something! The IAC is hooked up and everything, however, do the hoses to the IAC need to be connected a certain way, or can you just run any coolant lines to it? Another thing, I couldnt take off my crank pulley, and since the JR pulley is exactly the same, I just left my stock one. Would that make any difference? I mean, why would you have to change the crank pulley if they are the same size?
thanks in advance,
Alex
Old Apr 8, 2005 | 11:06 AM
yellowturbo's Avatar
sound like a IAC problem... be sure that all your coolant lines are ok... or it could be your timing.
Old Apr 8, 2005 | 11:23 AM
EJ1 wilcox's Avatar
Default Re: (yellowturbo)
The jumping idle could be a vacuum leak...
Old Apr 8, 2005 | 12:36 PM
s2kdre's Avatar
Default Re: (EJ1 wilcox)
check the gromets that hold your injectors in to the intake manifold they're probably smashed and now they are sucking in air causing bad idle
Old Apr 8, 2005 | 05:08 PM
bluebullet's Avatar
yeah what the two previous said, check for leaks, souds like bad vacuum.
Old Apr 9, 2005 | 08:11 PM
streetrage's Avatar
I called jackson racing and they said I have a vaccum leak... How would I find where it's coming from?
Old Apr 9, 2005 | 08:17 PM
Sonny's Avatar
Make sure the MAP and TPS connectors aren't reversed.
Sonny
Old Apr 9, 2005 | 09:36 PM
slow95's Avatar
Do you have a FIT valve? When I had my blower installed I had the same problem and it was the FIT valve. It's located under the throttle body.
Old Apr 9, 2005 | 10:14 PM
Tad's Avatar
Tad
Default Re: (slow95)
basically it sounds like u have a vacuum leak,
I had a problem when I first put mine on, it was sitting on top of the alternator,
so when torqued the IM down it didnt seal properly leaving a vacuum leak.
Old Apr 10, 2005 | 10:17 PM
streetrage's Avatar
is the FIT valve the same as the IAC? I checked for vaccum leaks with butane from a lighter but couldnt find any.. Could the PCV valve be leaking from the grommet or something? Thanks for all your replies..
Old Apr 10, 2005 | 10:29 PM
Tad's Avatar
Tad
Default Re: (streetrage)
well theres a valve under the tb,
and one behind it, on the stube,
check em both
Old Apr 15, 2005 | 10:54 AM
streetrage's Avatar
I was told that i have the wrong throttle body, so I bought an 98 EX throttle body and IACV, but the car runs worse, because my DX has a 3 wire IAC and the EX has a 2 wire IAC.. What should I do?
Old Apr 16, 2005 | 08:03 PM
streetrage's Avatar
never mind, It was the throttle body gasket. Stupid Kragen computer was wrong!!
Thanks to everyone for their help!
Old Apr 20, 2005 | 01:18 PM
Tad's Avatar
Tad
hahaa
dude,
rule #1 of autoparts,
never trust what the autoparts store/workers tells you!
Old Apr 21, 2005 | 09:49 AM
streetrage's Avatar
but the problem is...............I AM THE AUTO PARTS STORE WORKER!!!!!!!
I can assure you it was the computers fault, not me.....
Old Apr 21, 2005 | 10:26 AM
whatVTEC's Avatar
go to a real parts house like HONDA
just playin ........when you gonna go to the track again?
Old Apr 22, 2005 | 10:00 PM
streetrage's Avatar
I'm gonna wait till after this semester ends... So Ill probably go again around the end of next month
Old Apr 22, 2005 | 10:14 PM
Tad's Avatar
Tad
hahaha cool
so u got it working ok then?
hey u ran 12's with that turbo LS?
was that on street tires or slicks?
Old Apr 26, 2005 | 09:09 AM
streetrage's Avatar
Ya it's working great... for a DX at least! Ya I ran 12s on a internally stock LS. That was on M & H 24" slicks
hondaZvic
Sep 28, 2004 12:53 PM
hondaZvic
Sep 24, 2004 04:33 PM
jetpilot
May 24, 2004 05:50 AM
cnydelSolHybrid
Jul 19, 2003 10:08 AM
Malgerus
Aug 30, 2002 10:01 AM
