.::Anyone using this turbo::.
GT3076R
https://honda-tech.com/zerothread?id=1203081
what is the spool like?
or
I will be getting either this one or a SC61
85MM sleeved GSR 9:5:1
or
sc61 has full boost on my ls at 4.8k rpms, with that turbo you should have full boost a little over 3k but its gonna cost more than an sc61, sc61 use the same wheel as the gt35r.
On an 84mm B18c1 it will spool up fairly quick and have great top end. I actually have one on the way, I hope, so it should be here by Wenesday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevino002 »</TD></TR><TR><TD CLASS="quote">yeah I will be getting something next week. so did you get the GT30R? or SC61.</TD></TR></TABLE>
Originally I had ordered the GT3071R but problems came up. I changed my order to a GT3076R so I could get it next week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">
Originally I had ordered the GT3071R but problems came up. I changed my order to a GT3076R so I could get it next week.</TD></TR></TABLE>
the 3076R has the bigger compressor wheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
the 3076R has the bigger compressor wheel?</TD></TR></TABLE>
Correct
I would elaborate on this but I am helping BoostedCivicSedan assemble the last of the long block and get er dun tonight. Basically 71mm to 76mm.
- 0x64
Correct
I would elaborate on this but I am helping BoostedCivicSedan assemble the last of the long block and get er dun tonight. Basically 71mm to 76mm.- 0x64
I'm a little confused. what more is to be elaborated? what are the plans for the car? If you're just comparing quick spool, you're question has been addressed. If it's something else, like what will it do for you, and if it is a good idea, you have to ask the right questions... No one can read minds here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivicSedan »</TD></TR><TR><TD CLASS="quote">
Correct
- 0x64</TD></TR></TABLE>
sweet, i would have takent he 76mm too. can't get too big when purchasing a turbo.
Correct
I would elaborate on this but I am helping BoostedCivicSedan assemble the last of the long block and get er dun tonight. Basically 71mm to 76mm.- 0x64</TD></TR></TABLE>
redsikiller
May 23, 2006 06:44 AM
