Should i swap hx harness for 99-00 SI harness........b16 swap???
Old Apr 8, 2005 | 05:31 AM
ottobell22's Avatar
Default Should i swap hx harness for 99-00 SI harness........b16 swap???
I am doing a b16a (obd2) swap into a 1996 civic hx coupe w/chipped P28 from hondata and the obd1-obd2 adaptor. I'm looking at trading my hx harness for a 99-00 SI harness. Will this ease some of my wiring concerns, or should i stick with the hx harness and do the necessary plug conversions?
Also I'm doing a auto to manual conversion, since my HX was an auto, will this add to my wiring task??
Modified by ottobell22 at 6:50 AM 4/8/2005
Old Apr 8, 2005 | 05:45 AM
boomslang's Avatar
Default Re: Should i swap hx harness for 99-00 SI harness........b16 swap??? (ottobell22)
Stick with the HX harness. The 99-00 harness won't work without extensive repinning of some interior wires.
Old Apr 8, 2005 | 05:53 AM
ottobell22's Avatar
Default Re: Should i swap hx harness for 99-00 SI harness........b16 swap??? (boomslang)
I wouldn't have to do any extra wiring for the auto to manual conversion other than the usual vtec, knock sensor......etc??
Old Apr 8, 2005 | 06:16 AM
boomslang's Avatar
No, the pinout locations of the interior are different between 96-98 and 99-00. The plug is the same, the pinouts different.
Old Apr 8, 2005 | 06:22 AM
ottobell22's Avatar
I'll stick with the HX harness. I saw a post on honda-tech saying that I will need the rear engine mount from an SI, is this true or will my Hx mount work? we have the engine in, but only had time to put 2 mounts in.
1995integraGSR
Nov 20, 2014 05:21 PM
webafile
Sep 26, 2013 12:09 PM
USDM-EK4*
Aug 26, 2009 04:35 PM
BigRonDawg
Apr 25, 2006 09:37 AM
purpl7duece
Dec 3, 2002 01:45 PM
