jdm rear sway did you feel it was a good upgrade?
Old Apr 7, 2005 | 08:49 PM
PY 01-0972's Avatar
Default jdm rear sway did you feel it was a good upgrade?
there was alot of info in the search I did but only a few comments on this upgrade.
my car is a daily driver and i like to take some corners at the limit will this flatten out the car even more than stock in your opinions? Can i just put this without messing with the front and get a flatter feel to the car. its all stock. thanks for all who reply. I just want to make my daily commute a little funner
Old Apr 7, 2005 | 09:08 PM
BlueR's Avatar
Default Re: jdm rear sway did you feel it was a good upgrade? (PY 01-0972)
noticed it for like 2 weeks then i got used to it...
kinda like a clutch with a slightly stiffer pedal feel
but a great and easy upgrade for the price
Old Apr 7, 2005 | 09:21 PM
PY 01-0972's Avatar
thanks!
Old Apr 7, 2005 | 09:55 PM
nugen power's Avatar
I got a real good price on one brand new and sold my old one for the same
To tell you the truth i didnt feel much of a difference, but I did start entering corners a lot faster that I did with the stock one. It gave me more confidence.
I read somewhere that it is 19% stiffer than the stock piece if i remember correctly.
I say if you can get a good price on one($70-$80USD) go for it.
The install is very easy too just make sure you have the bushings and Dlinks
Old Apr 7, 2005 | 10:35 PM
mingbling96's Avatar
don't put polyurethane bushing on the sway bars. They might be stiffer.. but the squeaks every now n then makes the car sounds cheap. If i had a chance to do it over, i'd just put OEM bushings.
Old Apr 8, 2005 | 02:25 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: jdm rear sway did you feel it was a good upgrade? (mingbling96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">don't put polyurethane bushing on the sway bars. They might be stiffer.. but the squeaks every now n then makes the car sounds cheap. If i had a chance to do it over, i'd just put OEM bushings. </TD></TR></TABLE>
As far as urethane bushings go, just be sure to lube everything very well at the time of install.
Old Apr 8, 2005 | 06:35 AM
Flux's Avatar
Default Re: jdm rear sway did you feel it was a good upgrade? (LudeEFv2.0)
I have the JDM rear bar (with the poly bushings) and really have liked it. It is a perfect suspension change for those wanting to make some minor tweaks to the handling characteristics and balance of the car. If your car's balance needs more than just some refinement go back and work on other parts of the suspension first (springs, dampers, alignment, etc.)
Old Apr 8, 2005 | 12:46 PM
mugenracer's Avatar
What thickness is the USDM stock rear bar?
Also (and not meaning to hijack this thread)...i have a set of mugen rear sway bar bushings for my car but havent fitted them yet as i was looking at the OE ones and theyre in perfect condition. Is there any point fitting them or should i just leave them till the OE ones need changing? (sorry again for the semi-jack)
Old Apr 8, 2005 | 12:48 PM
Flux's Avatar
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">What thickness is the USDM stock rear bar?</TD></TR></TABLE>
USDM=22mm
JDM=23mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">just leave them till the OE ones need changing? (sorry again for the semi-jack)</TD></TR></TABLE>
Old Apr 8, 2005 | 01:15 PM
p nut's Avatar
OT: Does this upgrade bump you out of "stock D" class? It looks like changing out the front sway bar is okay, but the rear is not. However, since it's still OEM Integra part, would it still be kosher?
Old Apr 8, 2005 | 01:24 PM
Flux's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">OT: Does this upgrade bump you out of "stock D" class? It looks like changing out the front sway bar is okay, but the rear is not. However, since it's still OEM Integra part, would it still be kosher?</TD></TR></TABLE>
No, you cannot change to the JDM bar and remain in stock class...
Old Apr 8, 2005 | 01:31 PM
Opie's Avatar
uh oh, looks like some has a case of modifitis
Once you're not stock you can't stop
Old Apr 9, 2005 | 07:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
As far as urethane bushings go, just be sure to lube everything very well at the time of install.</TD></TR></TABLE>
no matter how well u lube it, it will squeak over time, unless you ahve those bushing sthat u can add grease on it...
kABLiuks
Honda Civic (2001 - 2005)
13
Mar 5, 2008 10:01 PM
Vantage
Aug 9, 2006 06:56 PM
briem2jdm
May 9, 2006 05:15 PM
PY 01-0972
Dec 17, 2004 12:50 PM
Toda Party
Feb 5, 2002 02:15 PM
