Need help,wastegate doesnt sit flush with the mani.
OK I plan on installing tomorrow but have one quick question. I test fitted the wastegate on the manifold and it doesnt sit flush. The wasgate kinda pokes out at the bottom. See attached pics. Do I just need a gasket? Other alternatives
Modified by Civicman86 at 9:14 PM 4/7/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict »</TD></TR><TR><TD CLASS="quote">it will seat fine once you tighten the bolts down</TD></TR></TABLE>
mine was same way
mine was same way
isn't it supposed to actually sit a little higher than the mating surface? i know mine did until i put alotta pressure on it (aka, tightened bolts)
Andrew 825SM
11
Mar 17, 2004 10:46 AM
