And................This is why I don't run Nitrous.... :O
Old Apr 6, 2005 | 09:54 AM
*Boostwerks*'s Avatar
Default And................This is why I don't run Nitrous.... :O
http://www.gotstang.com/gs_fil...y.wmv
This guy needs a
Old Apr 6, 2005 | 10:02 AM
B18C1CYA's Avatar
Default Re: And................This is why I don't run Nitrous.... :O (Bryson)
man that is some **** , haha
Old Apr 6, 2005 | 10:05 AM
JDMorgan's Avatar
what causes nitrous backfires?
Old Apr 6, 2005 | 10:06 AM
turboEGhatch's Avatar
That guy needs a kick in the *** for spraying the nitrous way too early.
Old Apr 6, 2005 | 10:07 AM
YiNYaNg's Avatar
Old Apr 6, 2005 | 10:18 AM
B18C1CYA's Avatar
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">what causes nitrous backfires?</TD></TR></TABLE>
well i used to use a 100 shot , and it happened to me when the throttle was not wide open , but all i lost was a throttle plate and iac valve , and a map sensor , lol
Old Apr 6, 2005 | 10:21 AM
JDMorgan's Avatar
Default Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">well i used to use a 100 shot , and it happened to me when the throttle was not wide open , but all i lost was a throttle plate and iac valve , and a map sensor , lol </TD></TR></TABLE>
is it just when detonation ignites the whole n2o/fuel mixture? were you at low rpm?
Old Apr 6, 2005 | 10:23 AM
B18C1CYA's Avatar
well i was still spraying and let off some so it closed the throttle some , but no never detonated, it was the last time i ran n2o , haha
Old Apr 6, 2005 | 10:24 AM
I've heard that it has some thing to do with the fuel puddling? I'm really not sure. I would think it would be a combination of not retarding the timing, and spraying too early...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">well i was still spraying and let off some so it closed the throttle some , but no never detonated, it was the last time i ran n2o , haha</TD></TR></TABLE>
Where did you have your jet(s) mounted?
Old Apr 6, 2005 | 10:25 AM
B18C1CYA's Avatar
Default Re: (Bryson)
yes the fuel does puddle , i noticed it after i would spray and shut the car off it would start and be realy rich , never realy understod y ,
Old Apr 6, 2005 | 10:26 AM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
Where did you have your jet(s) mounted? </TD></TR></TABLE>
the nozzle was in the intake tube right infront of the throttle body like 2" away ,
Old Apr 6, 2005 | 10:28 AM
wantboost's Avatar
Who is Mr Robot?
Mustang = ******* PWN3D
It's mean to say, but that made my day..... I almost fell out of my chair laughing
Old Apr 6, 2005 | 10:31 AM
tgreaves's Avatar
Default Re: And................This is why I don't run Nitrous.... :O (turboEGhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch &raquo;</TD></TR><TR><TD CLASS="quote">That guy needs a kick in the *** for spraying the nitrous way too early.</TD></TR></TABLE>
I agree..
Old Apr 6, 2005 | 10:32 AM
the nozzle was in the intake tube right infront of the throttle body like 2" away , </TD></TR></TABLE>
Hrm...
I definetly think the stang blew up because he sprayed way too early, with the nozzel too far from the TB. In the Vid, theres a part where he holds up the Intake tube and theres a huge hole melted into it...obviously the fuel puddled...but I've always been told that liquid fuel won't ignite...
Anyone know EXACTLY why nitrous sometimes backfires?
Old Apr 6, 2005 | 10:35 AM
B18C1CYA's Avatar
not shure y it back fires , but shure liquid fuel will ignite , it takes an open flame though,
Old Apr 6, 2005 | 10:36 AM
EJ1 wilcox's Avatar
Default Re: (wantboost)
Whoa....
That thing blew his IM in half! LoL.
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">not shure y it back fires , but shure liquid fuel will ignite , it takes an open flame though, </TD></TR></TABLE>
Same reason a lit cigarette wont ignite a pool of gasoline..
Old Apr 6, 2005 | 10:59 AM
hondaguyef's Avatar
Default Re: (tgreaves)
That's sucks . for learning the things the hard way.
Phil
Old Apr 6, 2005 | 11:00 AM
He sprayed the nitrous too early, the motor wasn't bringing in enough air to pull all the nitrous and fuel into the cylinders, fuel starts to puddle, you get any kind of a small backfire (which happens all the time) and your upper intake is basically a bomb. Generally you don't want to spray before anywhere from 3000-4000 RPM's with a single nozzle nitrous kit, depending on your motor and intake you're using.
Old Apr 6, 2005 | 11:34 AM
Boltz's Avatar
Default Re: (turboEGhatch)
"You're lucky that hundred shot of NOS didn't blow the welds on the intake!"
....oh wait, it did...
Time to get new rings from the mad scientist
Old Apr 6, 2005 | 11:40 AM
tgreaves's Avatar
Default Re: (Boltz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">"You're lucky that hundred shot of NOS didn't blow the welds on the intake!"
Better make sure the floorboard doesnt fall out as well..
Old Apr 6, 2005 | 11:44 AM
Boltz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Better make sure the floorboard doesnt fall out as well.. </TD></TR></TABLE>
I thought it was stylish to replace floorboard with diamond plate floormats. Damn
Old Apr 6, 2005 | 11:49 AM
ringgold's Avatar
I have seen something very similar happen to a mustang at Rockingham dragstrip in North Carolina. It blew his intake up also. I have heard that the fuel puddling is pretty common on the Mustang intakes? I dont know I used nitrous for awhile on my sohc coupe about 5 years ago and never really had a problem with it other than I annihilated a spark plug once.
That was cool video though pretty big explosion on the top of that engine haha
Old Apr 6, 2005 | 11:52 AM
tgreaves's Avatar
Default Re: (Boltz)
I thought it was stylish to replace floorboard with diamond plate floormats. Damn</TD></TR></TABLE>
It is, You just need to make sure that you bolt them in tight so the nitrous doesnt blow them off..
