ECU
Old Apr 7, 2005 | 07:55 PM
Del Slow's Avatar
Default ECU
the thing i proly know the least about is ECU's, i am about to have mine chipped, but what else does the ECU do beside rev limiter, speed cutoff, and VTEC. I am getting all three of those re written, but is there anything else that i can do just my chipping the ECU? thanks for the help
Old Apr 7, 2005 | 09:30 PM
Kendall's Avatar
Fuel maps, ignition maps, CEL's, etc. When I have my ECU's chipped, I usually have the knock sensor and pressure switch disabled, fewer things to worry about.
Old Apr 7, 2005 | 10:09 PM
mmuller's Avatar
Mad Scientist
Default Re: (Kendall)
what he sayd and you can also do a bunch of little things like full throttle shift, cel shift lights and 2 step
Old Apr 7, 2005 | 10:17 PM
Del Slow's Avatar
Default Re: (mmuller)
how safe is that to have the knock sensor removed?
Old Apr 7, 2005 | 10:23 PM
Kendall's Avatar
Default Re: (Del Slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Slow &raquo;</TD></TR><TR><TD CLASS="quote">how safe is that to have the knock sensor removed?</TD></TR></TABLE>
I've never once had a problem. Of course if you're using a P28, then you don't have knock sensor provisions anyway.
Old Apr 8, 2005 | 08:08 PM
Del Slow's Avatar
yeah, so if i am gonna get a p28 chipped, what would you recommend besides, puting it to a 8200 rev limiter, moving VTEC proly closer to 58, and removing the speed cutoff, what would help me a lot
Old Apr 8, 2005 | 08:22 PM
Kendall's Avatar
For what application?
Old Apr 8, 2005 | 10:04 PM
Del Slow's Avatar
basically it is too hard to get a hold of a P30 right now, so i am going to have the P28 re-written to run a jdm B16, and then chip it.... i am doing it through a local shop and i am not sure what program they will use
Scotty B
Mar 26, 2021 03:15 PM
ohsnapzafingcu
Oct 21, 2007 09:21 AM
dkrex001
Oct 1, 2006 10:34 PM
thehondaguru
Nov 26, 2003 06:55 AM
1.8T_EG
May 13, 2003 03:21 PM
