oil pressure gauge question
Old Apr 7, 2005 | 05:09 PM
4DRmafia's Avatar
Default oil pressure gauge question
alright well i got this oil pressure hooked up and working right and ofc i used the t fitting and used my stock sender as well. but how come my dummy light didnt light up? do i have to ground it to a certian palce for it ?
Old Apr 7, 2005 | 05:23 PM
4DRmafia's Avatar
aww come on fellas, this gorund issue is what i am sure of and this is holding me back.
thanks agian,
Ron
Old Apr 7, 2005 | 06:01 PM
RCautoworks's Avatar
Default Re: oil pressure gauge question (SkipMic2006)
Did you put the big sending unit on the block, if so to you. I have seen blocks crack from that. Anyways you might need to ground it, depending on how you hooked it up, if you used teflon tape and so on.
Old Apr 7, 2005 | 06:23 PM
4DRmafia's Avatar
no i didnt put the sender on the block, no way man i like my motor and dont want it to crack so i t it off on the firewall
so just need to know how to ground it off.
Old Apr 7, 2005 | 06:25 PM
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt put the sender on the block, no way man i like my motor and dont want it to crack so i t it off on the firewall</TD></TR></TABLE>
Good call , yep your gonna have to either ground the sending unit or ground the t fitting.
Old Apr 7, 2005 | 06:27 PM
4DRmafia's Avatar
the t fitting is brass, how will it work? i mean how can i hook it up on the t fittin or where on the sender
Old Apr 7, 2005 | 06:36 PM
You can solder it, or use a worm type hose clamp.
Old Apr 7, 2005 | 06:37 PM
4DRmafia's Avatar
okay ground on t fittin then where to? on the block ?
Old Apr 7, 2005 | 07:10 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">okay ground on t fittin then where to? on the block ?</TD></TR></TABLE>
To a ground ...
Old Apr 7, 2005 | 07:36 PM
4DRmafia's Avatar
okay but what part do i ground on the sender?
Old Apr 7, 2005 | 08:10 PM
Mr_CRX's Avatar
Just attach a ground wire to the T-fitting (either soldered or hoseclamped like said above) and then attach that to the firewall or some other grounding point.
migizzel
Feb 10, 2006 10:25 PM
codyb13
Apr 18, 2005 07:46 AM
PaImportTuner
Apr 7, 2005 05:30 AM
99Sivic
Jan 17, 2005 12:10 AM
Drag-Accord
Aug 11, 2004 08:13 AM
