AEM Pro's: What do I have to do to switch from RC440cc to RC750cc injectors?
Old Apr 7, 2005 | 02:15 PM
11psiTurboSI's Avatar
Default AEM Pro's: What do I have to do to switch from RC440cc to RC750cc injectors?
As far as the AEM EMS goes to make it run for another tune? I know about the wizard file battery offset or whatever it is... But I think you have to do something with the fuel maps???
Old Apr 7, 2005 | 02:23 PM
fast93accord's Avatar
Default Re: AEM Pro's: What do I have to do to switch from RC440cc to RC750cc injectors? (11psiTurboSI)
1st thing you need to do is go into "Primary Injector Battery Offset". Choose the injectors you are going to be using. Next, go into your fuel map. Highlight the entire map and right click. At the bottom click on change injector size/fuel pressure. And just put in your old injector size, and new injector size, and set fuel psi on both the same. And thats it, but you may still need to fine tune...
Old Apr 7, 2005 | 02:41 PM
Default Re: AEM Pro's: What do I have to do to switch from RC440cc to RC750cc injectors? (fast93accord)
Thanks
Old Apr 7, 2005 | 04:21 PM
Adriano's Avatar
you should go to aempower.com forums. They are very helpfull
Adriano
Old Apr 7, 2005 | 04:55 PM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast93accord &raquo;</TD></TR><TR><TD CLASS="quote">1st thing you need to do is go into "Primary Injector Battery Offset". Choose the injectors you are going to be using. Next, go into your fuel map. Highlight the entire map and right click. At the bottom click on change injector size/fuel pressure. And just put in your old injector size, and new injector size, and set fuel psi on both the same. And thats it, but you may still need to fine tune...</TD></TR></TABLE>
what he said
codenamezero
Engine Management and Tuning
Jun 12, 2011 12:50 PM
Y2K Si FBP
May 23, 2011 05:08 AM
EJ8chu
Apr 9, 2008 03:44 AM
c61lude
Jan 28, 2005 07:27 PM
Lyonel
Nov 13, 2001 09:50 AM
