94 accord EX Speedometer will drop to zero while driving on the freeway.
Old Apr 7, 2005 | 05:12 AM
newhondaowner29's Avatar
Default 94 accord EX Speedometer will drop to zero while driving on the freeway.
Lately when Im driving to work the car speedometer will suddenly drop to zero and then return to normal. This is a 94 Accord Ex with about 140k miles on it. Just did a very thourough 100k maintenence on it @ 130k miles when I got it. with honda oem parts including plugs and plug wires. Also has a new starter, radiator (which I think might be leaky already because I smell a burnt antifreeze smell when I get home from my 30 mile one-way commute), have cleaned out the egr ports. also Sefoamed recently, but only through the brake booster line.
Any ideas?
Thanks in advance.
Old Apr 7, 2005 | 09:23 AM
Schmitey's Avatar
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (newhondaowner29)
It's probably the vehicle speed sensor (VSS) mounted on the transmission itself. Do a search for it, its a fairly common problem.
Old Apr 7, 2005 | 05:17 PM
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (Schmitey)
Hey thanks!
Does anyone know where location and either how to replace or remove this part is in the Helms manual?
Thanks.
I have the pdf version and the search feature does not work on the pdf so I have to kinda thumb through it hoping for the best.
Old Apr 7, 2005 | 10:06 PM
sinister2c's Avatar
its easy..two 10mm bolts. I replaced mine around 140k
Old Apr 7, 2005 | 11:24 PM
Intense3.2's Avatar
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (sinister2c)
Well mine did that as well, and it ended up being that the alternator was not charging properly... but it might be your vss.
Old Apr 8, 2005 | 01:56 AM
Great now where the bleep is it?!?! Thanks.
Old Apr 8, 2005 | 06:25 AM
sinister2c's Avatar
on the back of the tranny right under the throttle body. Has a three wire plug going to it.
Old Apr 9, 2005 | 12:22 PM
brucebruce_vtec's Avatar
when that happened in my prelude, they told me it was the instrument cluster itself. does your VTEC still kicks in? if it doesn't than it maybe your VSS (on the top of the tranny) but if your car still drives normal, VTEC is kicking in at the right RPM and everything, then it maybe your instrument cluster itself.
Old Apr 9, 2005 | 05:03 PM
RotaryBzzzz's Avatar
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (brucebruce_vtec)
I had a battery going bad and it would do that. For some reason, my ABS system starting acting up as well. All problems disappeared when i installed a better battery.
I would:
1) clean all your grounds with a bit of sand-paper before you buy ANYTHING.
2) try switching out batteries w/ a known good battery (from a friends car if possible).
3) then try replacing the VSS sensor
If your car is an automatic, the 'D' light on your dash gear indicator might be flashing as well.
Regarding your antifreeze smell...you probably have a small leak in one of your other non-radiator connected hoses. Probably going to the heater. 10 year old hoses will tend to spring leaks like that when other components are played w/ & removed.
Check all the hoses for tightness as well. (might just be loose).
Old Apr 21, 2005 | 09:33 PM
roryamber's Avatar
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (RotaryBzzzz)
My 91 Accord EX Sport Wagon has an intermittent speedometer problem too. It will quit altogether or sometimes "bounce" off and on. Lately the "S" on the dash for my sports shifting will begin to flash as well.
Today the check engine light actually came on for a moment too.
Any ideas?
Old Apr 21, 2005 | 09:51 PM
Mr_EmO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">I had a battery going bad and it would do that. For some reason, my ABS system starting acting up as well. All problems disappeared when i installed a better battery.</TD></TR></TABLE>
had that same problem. changed the battery and all good.
Old Apr 21, 2005 | 11:11 PM
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (roryamber)
delete
Old Apr 21, 2005 | 11:54 PM
Mr_EmO's Avatar
delete?
Old Apr 22, 2005 | 05:47 AM
H2290's Avatar
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (Mr_EmO)
If it is your VSS you should get a CEL at some point. Even though it may not be showing check for any codes anyway since it is an intermittet problem.
Old Apr 22, 2005 | 05:59 AM
Vt3cTun3r's Avatar
My ignition coil caused my problem. It was shorting out and I ended up having to replace it. It caused the Speedo, ABS, Temp, and all my dash lights to come on. The car would actually shutter when I was driving it .. like it would loose power for a split second. Hope my experience helps.
Old Apr 22, 2005 | 06:26 AM
One Cam's Avatar
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (Vt3cTun3r)
Old Apr 22, 2005 | 11:09 AM
fleetmack's Avatar
Default Re: 94 accord EX Speedometer will drop to zero while driving on the freeway. (One Cam)
my alternator went out about 200 miles after this started happening (95lx)
Old Apr 24, 2005 | 08:26 PM
deserthonda's Avatar
yo vt3 in the future it is a good idea if you input all the symptoms your car is doing when you first ask for help it makes it easier for all of us who are trying to help to know excactly what car is doing and not just sppedo drops to zero ,,,speed sensor would not make abs lite temp and dash lite come on or car shutter if you would have put that info i am sure no one would have suggested speed sensor but actually a short of some kind
Fitz Williams
Jun 4, 2017 04:58 AM
totomark
Sep 27, 2007 07:45 AM
honest.hank
Dec 1, 2005 06:05 AM
94HondaAccordEX
Aug 27, 2005 03:44 PM
Accord Driver
Jul 18, 2003 09:26 AM
