Battery will go dead if car is not driven in 3 days
Old Jan 28, 2002 | 01:10 PM
97VTi's Avatar
Default Battery will go dead if car is not driven in 3 days
Any ideas? I have a 97 Civic VTi hb
with a B16a2 motor. Brand new battery already
Old Jan 28, 2002 | 01:13 PM
Greyout's Avatar
Default Re: Battery will go dead if car is not driven in 3 days (97VTi)
do you have a mad skillz type R alarm LED?
Old Jan 28, 2002 | 01:27 PM
97VTi's Avatar
Default Re: Battery will go dead if car is not driven in 3 days (JDM LUDE)
no.
Old Jan 28, 2002 | 01:35 PM
Gennady's Avatar
New User
Your alternator or generator may be going. Also, check your battery connections. Are you sure your battery is new? Some say you can fill it with distilled water, that might help....dont quote me though.
Old Jan 28, 2002 | 02:08 PM
94gsr's Avatar
Same thing happened to me with a brand new battery. It turned out to be bad - take it to an auto parts store & have them test it. If the battery's okay, have them test your alternator - it may have a short or bad connection that's allowing it to constantly drain power from the battery.
Old Jan 28, 2002 | 02:11 PM
MaddMatt's Avatar
Default Re: Battery will go dead if car is not driven in 3 days (Wont be beat)
My car club had the same problem with their bus last year. The alternator had a bad something-or-other.
Take the alternator to a shop to get it checked out. That's where I'd start, anyway.
Old Jan 28, 2002 | 03:36 PM
CanadaCivicSIR's Avatar
New User
Default Re: Battery will go dead if car is not driven in 3 days (MaddMatt)
You might have some sort of short leaking to ground in your electrical system.
However I would check your charging system first!!!!
Old Jan 28, 2002 | 04:54 PM
97VTi's Avatar
Default Re: Battery will go dead if car is not driven in 3 days (CanadaCivicSIR)
Thanks guys, appreciate the help. Unfortunately this is my second battery. Only thing I could think of is maybe the wiring for the stereo may be mixed up since its an aftermarket deck. I interior lights do not work???? anyone no the wire codes??? I hope its not the alt. those can be a little pricy!
Old Jan 28, 2002 | 05:15 PM
bob01721's Avatar
It sounds like a "parasitic drain" -- something's "on" when it shouldn't be. A trunk light? A glovebox light? A short somewhere?
Do you have an ammeter? If so, measure the battery current with the car turned off. There should be maybe 50mA going to the clock, ECU memory, stereo memory, etc., but that's about it. (BTW, that's ballpark number -- check a manual for your car if you have one.) If there's more current there than normal, start pulling fuses one by one until you find the circuit that's drawing the current and running down your battery.
Old Jan 28, 2002 | 05:51 PM
Jared's Avatar
Default Re: Battery will go dead if car is not driven in 3 days (bob01721)
When measuring with an ammeter most cars will come nowhere close to 50mA, more like 20 or 30. Even an Infinity Q45 with nav, cd, dvd, entertainment system, voice recognition, etc.. only draws 40.
Old Jan 28, 2002 | 07:17 PM
New User
Default Re: Battery will go dead if car is not driven in 3 days (Jared)
If you read the above post he say read it with the car off......
If your car draws 20, 30 or 40 Amps will car off bud. You got a serious problem!!!!
Old Jan 29, 2002 | 02:03 AM
irev210's Avatar
milli amps
not amps
mA
not AMPS
Old Jan 29, 2002 | 09:08 AM
New User
Default Re: Battery will go dead if car is not driven in 3 days (sirhatchback)
milli amps
not amps
mA
not AMPS
I know what mA are!!!!!
I am a journeyman electrician!!!
Put if a person does not put mA beside the number he is talking about then, you assume amps.
Oh and by the way an Infintity draws 1.3amps when shut off.
My friend has one and we tested it with an amp probe.
Old Jan 31, 2002 | 03:57 PM
97VTi's Avatar
Thanks for the great advice, hopefully I find the short amoungst the mess. Thanks again. I think a meter would be a great investment
Old Jan 31, 2002 | 05:14 PM
Jared's Avatar
I believe you're mistaken sir, I've tested them myself, even a basic Altima draws 20mA.
Old Jan 31, 2002 | 08:46 PM
gregv's Avatar
Default Re: sounds like a ground fault; read on
this sounds like a typical ground fault scenario; have you replaced any parts in your electrical system lately? by this I mean stereo, ecu, especially the alternator and/or battery. I have had "remanufactured" alternators that were faulty from the get-go. It also wouldn't hurt to check your engine grounding strap, and all other obvious earth (ground) connections. It could also be a duff battery. I have had a coulple of bad experiences with cheap after-market batteries. It would be worth checking all the wiring in your engine compartment for any obvious corroded connections/chafed insulation etc.
bet you 10:1 that it's the battery or the alternator (or a 6-pack wiring job!)
good luck
P.S. if you have the original alternator, check the bushes; these will go, and sometimes create havoc with the rest of the system
b18cEK
10
Nov 6, 2006 02:27 PM
KleenEX
Dec 30, 2004 01:52 PM
Tyler_Durden
Jun 19, 2003 09:55 AM
BK101
Jun 15, 2001 11:37 AM
