Tach & Speedometer Mechanics
Old Jan 29, 2002 | 04:50 PM
Quick 200k Mile Motor's Avatar
Default Tach & Speedometer Mechanics
I never took out the cluster to find out, but..
Tach is electrically (signal) driven, and Speedo is mechanically driven, right?
Old Jan 29, 2002 | 05:03 PM
bob01721's Avatar
Default Re: Tach & Speedometer Mechanics (Quick 200k Mile Motor)
Not on my Acura. The vehicle speed sensor sends electrical pulses to the speedo and odo driver circuits -- they're electrically driven. Same with the tach, which gets its signal from the igniter/coil circuit.
Old Jan 29, 2002 | 05:43 PM
tinkerbell's Avatar
yep, on the earlier models (pre 90's) the speedo is mechanic - called a pulsar unit...
later models used teh VSS on the tranny to drive the speedo circut.
hope this helps?
PS why are you interested?
t..
Old Jan 29, 2002 | 06:14 PM
Default Re: Tach & Speedometer Mechanics (tinkerbell)
mine is older than 90'
Old Jan 29, 2002 | 06:33 PM
fixhondas's Avatar
91 and back civics- cable driven 89 and back accords cable driven unsure about ludes.
Old Jan 29, 2002 | 09:56 PM
FitCRX's Avatar
Default Re: Tach & Speedometer Mechanics (fixhondas)
Im still learning...but on a 90 CRX b16a....the vss sensor is in the tranny? I got a code 17...speedo works fine...but I can't figure out what to replace..the peice at the tranny..or new cluster?
Old Jan 30, 2002 | 01:15 PM
fixhondas's Avatar
Default Re: Tach & Speedometer Mechanics (FitCRX)
if your guage cluster is USDM- and the speedo works- you might have a poor connection to the ecu or a bad cluster thingy.
Old Jan 30, 2002 | 07:39 PM
jetdriven's Avatar
my 91 teg has a speedo cable, the speedsensor is in the speedo head
Old Jan 30, 2002 | 09:57 PM
FitCRX's Avatar
Default Re: Tach & Speedometer Mechanics (jetdriven)
Which side is the head???
Old Jan 31, 2002 | 05:31 AM
accord_ex90's Avatar
My speed sensor is loose or something which causes my check engine light to come on. Does anyone know how to fix this? The repair manual says nothing. If I could locate it or see what it looks like then I could probably find one in a junkyard...
Old Jan 31, 2002 | 06:23 AM
rainforest's Avatar
Default Re: Tach & Speedometer Mechanics (accord_ex90)
the way to fix it is to either get a new cable or try to use something to keep it from shaking out. if your speedo cable is out than you will not get vtec so its something you want to fix.
Old Jan 31, 2002 | 10:04 PM
FitCRX's Avatar
Default Re: Tach & Speedometer Mechanics (rainforest)
Hes saying hes got a bad connection...or broke speed sensor....if the cable was loose then his speedometer wouldn't work...am I right? is your speedometer working?
Drola
Sep 14, 2011 07:26 AM
boyee1
10
Dec 15, 2007 10:07 AM
onefastasscivic
Jul 17, 2006 09:24 AM
TurboEM1
Jun 16, 2006 11:37 AM
civic889802
Jan 16, 2006 11:46 AM
