B16 + jdm 4-1
Old Jan 28, 2002 | 12:50 PM
S13 slide's Avatar
Default B16 + jdm 4-1
hello all, for the people w/ the b16 + a jdm 4-1 header, whats the clearance like? does it bang the crossmember, and how much clearance is between the header and the floor? i have a b18b + a Dc 4-1 header made for the teg and my header is about 2-3inches off the ground. just doin some research for my future rex.
Old Jan 28, 2002 | 12:58 PM
Lyonel's Avatar
Default Re: B16 + jdm 4-1 (bobo)
I have pics of it on my site. You'll have to cut a section off the cross member to fit it. It does hang quite low, just don't lower your car too much.
Old Jan 28, 2002 | 01:30 PM
S13 slide's Avatar
Default Re: B16 + jdm 4-1 (Lyonel)
thanks for the pics, does anyone have exeriance w/ the z10 radus arms and crossmember? does that kit allow more room for a 4-1 header? hmmm thanks
Old Jan 29, 2002 | 12:40 PM
EL Vap133's Avatar
Although I don't have a header on my B16 yet, I purchased a custom x-member from www.placeracing.com
Now I can slap on any header I want without cutting.
[Modified by Vap133, 9:41 PM 1/29/2002]
Old Jan 29, 2002 | 01:54 PM
MrFatBooty's Avatar
Default Re: B16 + jdm 4-1 (B!6@_gOnEn!3sEcOnDs...)
Personally I'd run a Comptech header for a '99-'00 Si with a 2.5 cat and custom 2.5" pipes. It'll flow nice but have much more ground clearance since it's a 4-2-1 and designed for the shorter deck height of the B16.
Old Jan 29, 2002 | 02:00 PM
S13 slide's Avatar
Default Re: B16 + jdm 4-1 (MrFatBooty)
does anyone make a 4-1 for the Si? thanks
Old Jan 29, 2002 | 02:05 PM
MrFatBooty's Avatar
DC does. Any B-series header will bolt up to any B-series head, it's just that the B18 headers hang a little lower because their oil pans are lower as well. You won't gain much ground clearance over a 2.5" collector B18 4-1 if you swap to a 2.25" collector B16 4-1. That's why I'd go with the Comptech. If you want a 4-1 you might as well get a 2.5" collector.
[Modified by MrFatBooty, 11:05 PM 1/29/2002]
Old Jan 29, 2002 | 03:09 PM
EL Vap133's Avatar
I got my custom x-member for $190 brand new. I think $300 is too much, IMO.
gringo7718
Aug 8, 2010 11:03 PM
HONDRETTI
Nov 6, 2007 06:34 PM
ArlssB17
Sep 26, 2006 09:37 PM
h22eg6
Mar 10, 2003 02:25 AM
EVOCELICA
12
May 9, 2002 05:28 PM
