header fitment
i am currently doing a b18 to a jdm b16 swap...i had a DC 4-2-1 header installed originally and i assumed it would fit...now i am having clearance problems under the block and im afraid i may have to take it to a shop to have it custom installed, what are my options? can i double up on gaskets?
The clearance issues are due to the B18's taller deck height. I'd suggest purchasing a new header designed for the engine. Doubling gaskets is a band-aid fix, and won't provide much additional clearance anyway.
thanks...anyone interested in a used header? im figuring the jdm will work pretty well based on my performance needs, for now...
how do a DC ceramic and jdm stock header compare?
There is no best header. Except one that is specifically designed for your engine with the mods you have on it. That being said, generally a 4-1 moves the power curve to the right. Best for high performance applications or race car. Decreasing torque and gaining top end HP (not by much tho). While a 4-2-1 will give an increase in torque at the low rpms, and not that much of a high HP gain. better for a street DD car. Search there are many different options and dyno graphs to help.
I just read your post again, and you are swapping to a B16. In that case, you should not have any clearance issues with a B18 header. However, to answer your other question, the Toda Racing manifold is probably the best off-the-shelf header you'll find for the B16.
thank you... yea i didnt think i would have any problems but the manifold is too snug against the block...i thought of doubling up on gaskets but as said its only a temp fix, i am determined so with any other suggestions tomorrow is another day...thanks again
Grand
14
Apr 23, 2005 08:31 AM
