b17 in ef staying obd 0
Old Apr 6, 2005 | 10:12 PM
TegRX91's Avatar
Default b17 in ef staying obd 0
can anyone help me to certiify exactly what engine harness i need to run this motor correctly in my 90 crx si?? my mom is going nuts with all the parts in the garage and i need to get this stuff up and running before she has another cow......i have been searching and collecting parts for weeks now and i cannot find this info anywhere on the net... not very many people have this motor in these cars running obd 0.......thanks for your responces in advance
Old Apr 6, 2005 | 10:16 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: b17 in ef staying obd 0 (TegRX91)
OBD0 PR3
Old Apr 6, 2005 | 10:17 PM
eda6's Avatar
modify the 90 crx si harness
Old Apr 6, 2005 | 11:01 PM
TegRX91's Avatar
Default Re: b17 in ef staying obd 0 (eda6)
can anyone specify what plugs i need to modify on my stock harness? i am aware that the dissy is different but are there any others that are not the same or that do not plug in?
Old Apr 6, 2005 | 11:21 PM
Malgerus's Avatar
To run OBD-O on that OBD-I GSR engine, you need to find an OBD-O B16A distributor (LS can be modified to fit), add wires for VTEC and the knock sensor, and run a PW0 or PR3 ECU. OR, you can run OBD-I easily by using an OBD-I Computer (either the B17 one or the Del Sol VTEC one) and splicing your stock CRX harness distributor plugs into the B17's distributor (they won't match up otherwise).
Old Apr 7, 2005 | 07:03 AM
TegRX91's Avatar
Default Re: b17 in ef staying obd 0 (Mr. S)
is it possible to just extract the pins and change the plug they are in to?
Old Apr 7, 2005 | 05:18 PM
mar778c's Avatar
Community Builder
Community Influencer
Get a conversion harness from rywire.com. It will save you a lot of the hassle of wiring up your car.
Plus, you can run it obd-1 like it was meant.
Old Apr 7, 2005 | 06:36 PM
Lu DC2's Avatar
Run it exactly like you would with a B16A in your 90 CRX! OBD0 is good but if you already have the OBD1 distributor, get jumper harness! What ECU do you have?
Modified by b16a@9krpm at 8:31 PM 4/7/2005
Old Apr 7, 2005 | 07:23 PM
Deetz's Avatar
Crazy Honda Guy
Stay with the obd1 the B17 is set for already. You would be downgrading by going back to OBD0, plus all the hassel of getting a new distributor, ecu and messing around with harness.
Old Apr 7, 2005 | 07:29 PM
TegRX91's Avatar
Default Re: b17 in ef staying obd 0 (b16a@9krpm)
my friends shop said they could chip my pm6 90 ecu with parts out of the auto computer to run the dohc vtec for 150 or i can get a chiped obd 0 b16 ecu off another guy for 200
plus i can swap my dissy basically for free and use my stock harnesses for free too
common guys this is all my marbles please help
Old Apr 7, 2005 | 09:21 PM
Bee17hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">To run OBD-O on that OBD-I GSR engine, you need to find an OBD-O B16A distributor (LS can be modified to fit), add wires for VTEC and the knock sensor, and run a PW0 or PR3 ECU. </TD></TR></TABLE>
thats what im running right now till i get all the parts i need to convert it to obd1.
pm me if you have any question if you chose to run obdo.
Old Apr 7, 2005 | 09:29 PM
boosted_hatch_216's Avatar
Default Re: b17 in ef staying obd 0 (Bee17hatch)
why not just go obd1? it seems like itd be easier. just get the harness and ecu right?
Old Apr 7, 2005 | 10:06 PM
TegRX91's Avatar
Default Re: b17 in ef staying obd 0 (boosted_hatch_216)
as simple as it would be to convert to obd 1...it will cost me more moula i dont have to spend right now! so i cant afford not to let this opportunity of learning to pass me by.... i know it can be done so i want to do it and thats why im here thanks for any helpers guys
T3k C
Apr 20, 2021 06:35 PM
em1effekt
11
Jan 21, 2012 05:37 AM
bradennicely
11
Jul 21, 2009 07:12 PM
SimbaDogg
14
Nov 28, 2003 10:49 AM
RuffRhyno
Aug 12, 2002 04:22 PM
