Mating a Greddy D-series turbo kit to a B-series motor..
Old Apr 6, 2005 | 08:36 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Mating a Greddy D-series turbo kit to a B-series motor..
A buddy of mine has a chance to purchase a D-series greddy kit w/ intercooler for a real good price. Unfortunatley he has a B-series motor (b18b). I have seen some posts a few times about people modifying the D-series manifold to fit onto a B-series motor.
I am basically doing all the work on installing this and would like to know if anyone has any experience in doing this conversion. I would also like to know how much potential a little turbo can make on a Bseries motor.
Thanks
+DS
Old Apr 7, 2005 | 12:01 AM
gldndrgn14's Avatar
Default Re: Mating a Greddy D-series turbo kit to a B-series motor.. (D4rk5y3D)
all you need is the greddy b series manifold, or the hks manifold.
Old Apr 7, 2005 | 06:15 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: Mating a Greddy D-series turbo kit to a B-series motor.. (gldndrgn14)
up for any more ideas
Old Apr 7, 2005 | 07:41 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Match the manifold bolt holes to the DOHC head.
It's not hard, just get a stock DOHC gasket and overlay it on the SOHC manifold.
Old Apr 7, 2005 | 10:29 AM
X2BOARD's Avatar
The bolt pattern is a lil different with the BIG difference at the end bolts. You can seriously ghetto rig the manifold with a dremel to fit the B head, but it will look ghetto as hell and be prone to exhaust leaks.
The cheapest option short of buying a B series manifold is to go to a machine shop that has a CNC machine, take them a B series exhaust manifold gasket and have them copy the shape and sell you a CNC cut flange. Then take the D series manifold, cut off the existing flange and weld on your new B flange.
Hit up the ports with a grinder to clean up the edges and open the ports some and voila... Ghetto engineering at it's best and it won't look or function too badly either.
Old Apr 7, 2005 | 05:14 PM
vtecmissle's Avatar
Default Re: (X2BOARD)
the hks manifolds new are about 225 i would use that because they use the same turbo.
Old Apr 7, 2005 | 05:58 PM
X2BOARD's Avatar
Well the re done flange will cost about $80-$100 with the welding, etc...
But damn... an actual HKS manifold is only $225 new ? Damn, I've been out of the boost game too long !
Old Apr 7, 2005 | 07:25 PM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gldndrgn14 &raquo;</TD></TR><TR><TD CLASS="quote">all you need is the greddy b series manifold, or the hks manifold.</TD></TR></TABLE>
you beat me to it!
that's what i'd do. Some people may get away with modifying the greddy d manifold for the b head but it can lead to cracking or leaking exhaust fumes.
Old Apr 7, 2005 | 08:50 PM
Evo-man@20psi's Avatar
Good luck man she is gonna spool quick
bumpin_bass
Jun 29, 2009 01:02 PM
99ls
Apr 27, 2003 09:48 AM
cvcc
Nov 22, 2002 02:54 PM
prjctCIVIC
Jul 24, 2001 05:10 PM
