Golden Eagle Intake Manifold...
Old Apr 6, 2005 | 07:17 PM
LSEGHATCH's Avatar
Default Golden Eagle Intake Manifold...
I was checking this mani. out and was wondering how it dyno'd (if it did) and how it would compare to an intake mani such as the AEBS Typhoon. Is it worth the 500+?
Thanks
Old Apr 6, 2005 | 08:02 PM
SOHCmaster's Avatar
The golden eagle is a drag type top end intake manifold, Almost idenical to the STR..
Old Apr 6, 2005 | 08:12 PM
LSEGHATCH's Avatar
Default Re: (PK SPEED)
Yes but how does it perform compared to the AEBS. Though two different styles of manifolds, I'm thinking it would be worth spending some extra money to get my car done right
Old Apr 7, 2005 | 08:14 AM
LSEGHATCH's Avatar
Default Re: (LSEGHATCH)
Anyone?
Old Apr 7, 2005 | 09:03 AM
blackmagicCRX's Avatar
The AEBS will prolly have a better low end, but the GE will have a much better top end. But it all depends on your setup and what your goals are.
Old Apr 7, 2005 | 11:25 AM
LSEGHATCH's Avatar
Default Re: (blackmagicCRX)
Well my goals are to have a 500 or + hp eg honda civic. Using a bored ls/vtec, sc61 turbo, big FMIC, Head Work (ported, cams, valves/springs, etc...) and a fully built bottom end from exospeed There is more but I don't like going into detail about my setup..only enough that is needed
Old Apr 7, 2005 | 04:37 PM
SOHCmaster's Avatar
Then yes get the GE.
Old Apr 7, 2005 | 07:37 PM
Db1_77's Avatar
...the setup you menioned is almost the entire engine. You even mentioned the type of charger you're using. Way to keep it under wraps champ.
"I WANT A DRAG CAR" would have been just fine. j/k
Old Apr 8, 2005 | 11:30 AM
LSEGHATCH's Avatar
Default Re: (hatch77)
Well some people would "need" to know what type of turbo i'm using just to see if I'm legit. I didn't metion tuning, FMU, Internals, Boost I was going to run, etc....
Thanks for not totally flaming though
integranator
Apr 24, 2007 06:24 PM
HT Username
Apr 3, 2005 12:00 PM
TurboTeG4
Jul 8, 2003 09:12 PM
