enkei rpf1
Old Apr 6, 2005 | 04:48 PM
DIP_SET FoReVr's Avatar
Default enkei rpf1
were can you find these wheels, in 15x6.5?
Old Apr 7, 2005 | 07:25 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: enkei rpf1 (DIP_SET FoReVr)
why in 5.6''?
stan
Old Apr 7, 2005 | 08:48 AM
Default Re: enkei rpf1 (Stan D)
why not in 15x6.5? but i just realized that they only come in 15x7.... so you know were i can get them?
Old Apr 7, 2005 | 09:11 AM
hybridmoments's Avatar
hey. cheapest i've seen them. $189 each for the RPF1
that is crazy cheap.
Good-Win racing. they also have the Kosei's cheaper then Tire rack
http://www.good-win-racing.com...heels
Redshift motor sports sells RPF1 for like $195, and offer them mounted and balanced with Azenis RT-215 for $285
Old Apr 7, 2005 | 09:25 AM
Default Re: enkei rpf1 (hybridmoments)
good-win-racing is a good place, cheapest i found them.
i got my TDR pro1 there, good people
stan
Old Apr 7, 2005 | 11:29 AM
also my will these wheels fit fine on 195/50 falken ziex rubber? and do i need to roll my fenders because of the 15x7, cause my 95 coupe is like 3 inches off the ground, and im not raising it.
Old Apr 7, 2005 | 11:30 AM
one more thing what offset should i get??
Old Apr 7, 2005 | 11:37 AM
the tyre will fit fine, although i would consider 205 width. get 40mm or 42mm offset and they should fit without any issues. my 15x7 wheels are 40mm and 195 fits perfectly, if not a tad narrow.
stan
Old Apr 7, 2005 | 11:45 AM
any rubbing if im that low?
Old Apr 7, 2005 | 12:39 PM
if you are running less then 205's the 41mm will be good.
with the 35mm offset ones you can run 225/45/15, but you have to give your fenders a major WORKOUT and roll those babies, hit um with a sledgehammer from inside the wheel well. could always run fenderless! just imagine how much cooler your brakes could run!!
Old Apr 7, 2005 | 03:51 PM
cuz_ican's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">the tyre will fit fine, although i would consider 205 width. get 40mm or 42mm offset and they should fit without any issues. my 15x7 wheels are 40mm and 195 fits perfectly, if not a tad narrow.
stan</TD></TR></TABLE>
smbignick
May 3, 2016 06:31 PM
michaelsej1
Feb 23, 2011 08:37 AM
hondapeeler
Dec 2, 2010 08:59 AM
JDM SLICK
Apr 13, 2006 02:38 AM
SantaCruz92Si
Jul 22, 2003 01:36 PM
