Will a bad brake booster cause a fast idle problem on my 87 civic?
Old Apr 6, 2005 | 01:24 PM
toolhands72's Avatar
Default Will a bad brake booster cause a fast idle problem on my 87 civic?
Hello, club members
I have a bad brake booster that is plug off for now and a fast idle problem.Can these be link together? The Honda has (1500) 1.5LT Japanese motor with a Keihin 3 barrel carburetor and it is a manual 4 speed if this helps.I wasted money putting two carburetors on the car and I still have the same problem.The problem is that it has a hard start up and the idle is high at start up.The car runs great after you start to drive it, but when you come to a stop it's back up there.It also diesels a bit on shut off.I replaced the cap, rotor, wires, plugs and set the timing just in case.I check with the carb cleaner trick to check for vac. leaks, but I found no leaks.It might be a sensor also, but which thermovalve would it be? The head one? The block one?, or the radiator one? The fan works and the gauge works inside, so I don't know what to do next.Can anyone help? I would be greatful. Thank you!
Old Apr 7, 2005 | 06:40 AM
chameleon's Avatar
Default Re: Will a bad brake booster cause a fast idle problem on my 87 civic? (toolhands72)
while parked try plugging up the vacuum to the brake booster, i havent come across a brake booster leaking vacuum but if it does then its letting air in the motor which would cause the higher idle and surging problems.
Old Apr 7, 2005 | 10:55 AM
Default Re: Will a bad brake booster cause a fast idle problem on my 87 civic? (chameleon)
Thank you for your reply to my post. I plug off the booster with a rubber cap, but it might be leaking out of the cap. With the booster hooked up it makes a loud air leak. I will replace it soon and hope to fix the problem. I have another question if you can help. Is it normal to have back pressure when you open the gas cap? It make a loud swoosh noise and air blows by.I wonder if the gas tank vent has a problem. Thank you again for your post!
supertuner91ef
Dec 20, 2007 05:40 PM
SoEvoL
Nov 14, 2006 06:20 PM
EGkid
Jun 1, 2005 12:03 PM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
