HONDATA boost cut/boost limiter not working
Old Apr 6, 2005 | 07:41 AM
B00STED Si's Avatar
Default HONDATA boost cut/boost limiter not working
hey guys, just wanted to see what anyone thoughts on this one are...
my turboXs manual dual stage boost controller sucks, boost fluctuates all the time, and today i noticed it leveled off at 15.5lbs (usually its around 12-13lbs) and my boost cut is set at 15lbs even (i have a 1lb spike before it evens off, so usually at even 14lbs itll cut off) but it leveled off at 15.5lbs, so it had to spike to around 16.5 or so... I checked the s200b unit and no blinking red light or anything, help! i dunno why the hell its not working....
Old Apr 6, 2005 | 07:54 AM
Mase's Avatar
Default Re: HONDATA boost cut/boost limiter not working (B00STED Si)
your 3 bar and boost gauge probably arent reading identical. try setting the boost cut lower.
Old Apr 6, 2005 | 08:05 AM
B00STED Si's Avatar
Default Re: HONDATA boost cut/boost limiter not working (Mase)
the MAP sensor must be right and the boost controller is off b/c theres no way that im hitting 15.5lbs, if the boost cut isnt working then the entire tune wouldnt be working b/c its built into the tune, and the s200b red light is staying solid, im guessing the boost gauge is off a little, but todays the hottest its been all year so im guessing the heats screwing with the readings....
Old Apr 6, 2005 | 08:06 AM
B00STED Si's Avatar
or could the map sensor have gone bad? if it goes bad tho wouldnt the hondata notice?
Old Apr 6, 2005 | 09:42 AM
B00STED Si's Avatar
anyone?
alpha
Sep 26, 2005 09:09 AM
philipwight
May 4, 2004 08:48 PM
ATS*Mark
Feb 18, 2004 01:25 PM
_Shadow_
Nov 23, 2001 11:16 AM
Ray
Jul 7, 2001 07:34 PM
