HONDATA boost cut/boost limiter not working
hey guys, just wanted to see what anyone thoughts on this one are...
my turboXs manual dual stage boost controller sucks, boost fluctuates all the time, and today i noticed it leveled off at 15.5lbs (usually its around 12-13lbs) and my boost cut is set at 15lbs even (i have a 1lb spike before it evens off, so usually at even 14lbs itll cut off) but it leveled off at 15.5lbs, so it had to spike to around 16.5 or so... I checked the s200b unit and no blinking red light or anything, help! i dunno why the hell its not working....
Re: HONDATA boost cut/boost limiter not working (B00STED Si)
your 3 bar and boost gauge probably arent reading identical. try setting the boost cut lower.
Re: HONDATA boost cut/boost limiter not working (Mase)
the MAP sensor must be right and the boost controller is off b/c theres no way that im hitting 15.5lbs, if the boost cut isnt working then the entire tune wouldnt be working b/c its built into the tune, and the s200b red light is staying solid, im guessing the boost gauge is off a little, but todays the hottest its been all year so im guessing the heats screwing with the readings....
philipwight
05-04-2004 08:48 PM
