engine knock after rebuild, gets worse turning left !!
Old Apr 6, 2005 | 07:08 AM
JordanCivic's Avatar
Default engine knock after rebuild, gets worse turning left !!
B16, just had the block built with wiseco pistons and h beam rods, slight OS pistons, all new bearings and assembly done at proff garage.
The engine is very quiet at idle, start to make a slight knock when driving in a straight line, nothing major, think this may be to do with the bigger clearances for the pistons? but as soon as i start to turn right, lightly on the gas, the engine makes a horrible droaning noise and the knocking gets worse, rising with rpm. Turning left has the opposite effect and the engine returns to being quiet.
Ideas guys????
Old Apr 6, 2005 | 09:08 AM
zacdaddy77's Avatar
Default Re: engine knock after rebuild, gets worse turning left !! (JordanCivic)
I would check your pulleys sounds like it has something to do with your power steering.........are you sure its not a cv joint bad
Old Apr 6, 2005 | 07:09 PM
PrettyLude's Avatar
loose belts can make knocking noises
Old Apr 10, 2005 | 09:58 AM
Qfactor's Avatar
hope is not your thrust whasers on your crankshaft maybe they forgot to install them. check for side to side(back n forward) movement.
Old Apr 10, 2005 | 10:28 AM
ExospeedAMcrx's Avatar
missing thrust washers can make the crank move and cause some probs obviously.
I had a friend that bought a new EP a couple years back and it would knock and shut off everytime he turned a certain direction. The dealer couldnt figure it out until they tore down the motor and found there were no thrust washers in the stock motor.
Old Apr 10, 2005 | 05:24 PM
PrettyLude's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">missing thrust washers can make the crank move and cause some probs obviously.
I had a friend that bought a new EP a couple years back and it would knock and shut off everytime he turned a certain direction. The dealer couldnt figure it out until they tore down the motor and found there were no thrust washers in the stock motor.</TD></TR></TABLE>
yikes
JDM_ego2033
Apr 12, 2018 05:01 AM
landos2k
Honda S2000
Aug 14, 2015 12:42 PM
deadmonday08
Honda Civic (2001 - 2005)
Jan 22, 2011 10:06 AM
fastlane2
Aug 22, 2009 01:36 PM
96Spec Ek
Dec 23, 2005 12:17 PM
