reasons why i my car is burning oil
Old Jan 28, 2002 | 09:22 AM
JaEz's Avatar
New User
Default reasons why i my car is burning oil
now i know it would probably help if i listed my entire setup, but before i go and do that....are there any general reasons why my car would be doing this.
i basically have a DRAG III kit on an integra LS with some fuel upgrades only running 5 psi.....
i got in an accident and the engine wasnt messed up by it, but i havent driven driven the car for about 2 months. i'll start the car and drive it up around my neighborhood, but i dont actually drive, drive it. would that have any effect?
any ideas?
thanks for the help guys
jase
Old Jan 28, 2002 | 09:49 AM
BoM's Avatar
BoM
Default Re: reasons why i my car is burning oil (JaEz)
worn rings?
how about a compression test?
Old Jan 28, 2002 | 10:52 AM
JaEz's Avatar
New User
Default Re: reasons why i my car is burning oil (BoM)
sorry, i guess i should have put the year down to0....its a 2000 LS only 30k miles.
Old Jan 28, 2002 | 10:56 AM
b18bturbo's Avatar
its probably worn rings excessive blow by. therefor causing you to burn some oil. you need to do a leak down test.
Old Jan 28, 2002 | 11:11 AM
turboteg96's Avatar
Sometimes on an older engine the valve seals will wear. Also, try changing your oil, throw some synthetic in there. I find with my integra it wont burn oil until about 3500 kl into the oilchange when the viscosity begins to break down.
Old Jan 28, 2002 | 11:27 AM
BoM's Avatar
BoM
Default Re: reasons why i my car is burning oil (turboteg96)
even though its a 00' engine
the turbo can damage rings over a small amount of time.
u must test that.
Old Jan 28, 2002 | 11:32 AM
JD_B18CDX's Avatar
If rings are not worn, check Valve seal.
There is the only other way your engine will burn oil.
Otherwise, oil is leaking somewhere.
Old Jan 28, 2002 | 11:36 AM
JaEz's Avatar
New User
Default Re: reasons why i my car is burning oil (johnd)
cool, thanks alot everyone. i'll look in to all of that.
JBzaLude
Apr 15, 2006 06:09 AM
todbld
Oct 20, 2005 11:50 AM
HT Username
19
Apr 14, 2005 01:04 PM
Prelussion
May 4, 2002 09:08 AM
DaeDae12
Nov 3, 2001 07:10 AM
