Irregular Oil Consumption
Old May 3, 2002 | 04:37 PM
Prelussion's Avatar
Default Irregular Oil Consumption
My oil seems to discipate very rapidly! I changed it abo9ut a week ago, then the dip stick barely shows oil....I don't leak any and there are no sings of smoke. My compression is 150 across the board. then engine does have 130k on it (LS engine B18b) 5w30 was used last fill up.
Old May 3, 2002 | 04:50 PM
aeolus's Avatar
Default Re: Irregular Oil Consumption (Prelussion)
well,many miles do you have till you have to add oil?How much oil do you have to add?Info like this would help us out
Old May 3, 2002 | 05:41 PM
Prelussion's Avatar
Default Re: Irregular Oil Consumption (aeolus)
added a quart about 500 miles after i filled up
Old May 3, 2002 | 05:53 PM
Rocket's Avatar
check your pvc valve.
Old May 4, 2002 | 07:44 AM
non-VTEC's Avatar
do you drive the car hard?
Old May 4, 2002 | 09:08 AM
Prelussion's Avatar
Default Re: Irregular Oil Consumption (non-VTEC)
yes i do drive the car hard sometimes, not all the time, i'm thinkin i might have mad rings, since comp. is down at 150 like we discussed earlier.
WIhondas
Honda CR-V & Element
Nov 2, 2011 07:22 AM
r.etheridge
21
Feb 11, 2011 07:33 PM
creator1322
Sep 20, 2007 03:09 PM
return_2020
Jul 31, 2005 07:33 PM
crxhybrid85
Apr 18, 2005 06:47 AM
