Best Amps for Car Subwoofers?
I'm using 4 JL audio w7, i haven't have time to make the box for it, but i'm gather parts for it already. Before i was using a Zapco 750.5 amp and i had only 1 w7 back then. I know let alone the Zapco amp i have won't power 4 w7's. So what other amp is good? Or should i just buy 2-3 more Zapco amps? Let me know! This will all fit into a 90 Crx
This setup isn't too bad either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SexyAzNMami »</TD></TR><TR><TD CLASS="quote">I'm using 4 JL audio w7, i haven't have time to make the box for it, but i'm gather parts for it already. Before i was using a Zapco 750.5 amp and i had only 1 w7 back then. I know let alone the Zapco amp i have won't power 4 w7's. So what other amp is good? Or should i just buy 2-3 more Zapco amps? Let me know! This will all fit into a 90 Crx
</TD></TR></TABLE>What size W7s ? Makes a big diff., 10" are 300watt and 12" are 750watt and the 13" are 1000watt go to http://www.jlaudio.com for recommended box size and wattage and possable JL audio amp/amps. The way I see it, if you have 4 13" W7s you are going to need 4000watts, that would be 4 JL 1000/1
94
94
the w7's are all 13 inch. I assume JL doesn't make exclosure boxes to where 4 13 inch will fit all together. For the amps, I'm going to stick with Zapco Series.
how bout JBL 1200.1's there nice subs , i'm running one right now on my Xtant X1244's and it hasn't given me any problems
get the zapco competition series not the reference since your gonna be powering that many subs. I have the zapco 1100 reference and its unbelievable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SexyAzNMami »</TD></TR><TR><TD CLASS="quote">the w7's are all 13 inch. I assume JL doesn't make exclosure boxes to where 4 13 inch will fit all together. For the amps, I'm going to stick with Zapco Series.</TD></TR></TABLE> Not that I know of, [speaker box] but with 4 of them and the power you are going to need to drive them, the box/boxs will have to be "hella", min. 1" MDF, braced all to hell, [every seam every 4 to 5 inchs] even a front to back post between each speaker, predrill, glue and screw the box together, [no brad nails] seal the inside of box with fiberglass resin then silicon all the seams just to make sure
94
94
Fuster_Cluck
Audio / Security / Video
Aug 8, 2003 05:57 PM
Btw, what size are the w7's?
