using 3m window weld to fill in ripped bushings- your thoughts...
i recently picked up a 91 hatch. i found that the bushing that bolts the front of the rear trailing arm to the bottom of the chassis is kinda ripped and torn. this being my beater car i dont wanna spend tons of cash, so i think im gonna use some window weld to fill it in and stop it from ripping more. what do u guys think of this?
isn't window weld pretty much silicon? Unless its a harder compound with super adhesive abilities, it won't do much. A long time ago, I filled engine mounts with various silicon products, and the fillings would just pop out after a while.
hmmm interesting. ive heard about numerous dsm guys using this to fill in their motor mounts, and they make 3,4,500 whp. i just kinda wanted to have this prevent or prolong the bushing from completely ripping...
I heard of this being used to stiffen mounts as well, but I'm not sure it's going to work very well on a mount that's already ripped.
But it won't hurt to try...
I did it before, afterwards car rode very well except it would snap oversteer on bumps. There's a lot of bridges where I live with a lot of irregularities on them - when hitting these irregularities the rear would sometimes step out!
Not a pleasant experience, I don't recommend filling the bushings unless you're desperate. Honda replacements are only $60 CDN.
oh...I'm sorry, I missed the fact that he was talking about suspension bushings...no way would I do that on a suspension bushing.
I filled mine for a short time before replacing them with Mugens. It didnt seem to make much of a difference. There is also a Rubber-based product you could get at home-deopt that comes in a caulking tube...its used to mount plumbing standpipes that stick out of the roof. It might be harder when it dries.
i guess im just trying to not have the bushing rip all the way. ill see what happens
matt, mine are done, i just did my rear disk, made a big difference, i went from ripped to filled bushings, and it made it much stiffer, go for it!!!
Brett
Brett
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">matt, mine are done, i just did my rear disk, made a big difference, i went from ripped to filled bushings, and it made it much stiffer, go for it!!!
Brett</TD></TR></TABLE>
damn good to hear. now that i got my coupe up and running i can have some downtime on my hatch. ill be doing this soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">i went from ripped to filled bushings, and it made it much stiffer, go for it!!!</TD></TR></TABLE>
Have you tried pushing it hard yet? Attend one autocross and tell me if it doesn't snap oversteer. I thought it was great, too, until I actually pushed the car and it wanted to spin on me every time I hit a minor imperfection in the track. Now I have some replacement arms with ripped bushings and I ain't filling them in again... it may be noisy, but at least it's not unpredictable anymore.
I have used 3m Poly in 3 sets of mounts already; it makes a very noticeable difference.
its not silicone; its polyurethane.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">I have used 3m Poly in 3 sets of mounts already; it makes a very noticeable difference.
its not silicone; its polyurethane.</TD></TR></TABLE>
Where did you get the 3M poly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agent87 »</TD></TR><TR><TD CLASS="quote">
Where did you get the 3M poly?</TD></TR></TABLE>
its called window weld, and you can get it from Napa.
si90rex
Welding / Fabrication
16
Jan 16, 2008 12:07 AM
Project_ED8
27
Oct 24, 2006 11:35 AM
Rod.
Dec 31, 2005 07:05 AM
