need help car is hesitent
Old Apr 5, 2005 | 08:17 PM
civicferio8381's Avatar
Default need help car is hesitent
I have a 1992 Integra GSR and under normal acceleration it tends to hesitate during mid rpm range in 2nd and 3rd gear . I think it might be the fuel pump or fuel filter.Any help would be great
P.S It doesn't do it under fast acceleration
Old Apr 5, 2005 | 08:36 PM
Old_Honda's Avatar
Default Re: need help car is hesitent (civicferio8381)
Check out your spark plugs, wires, dizzy cap & rotor, and fuel filter. I was having the same problem and it turned out my plugs were gone, but it could be any of these things. Good luck!
Old Apr 6, 2005 | 01:33 AM
s2kdre's Avatar
Default Re: need help car is hesitent (OldGSR)
what octane do you use?
Old Apr 6, 2005 | 05:27 AM
RSRintegra90's Avatar
Default Re: need help car is hesitent (jdmhonda)
I had the same probblem on my 90 RS but when i put my exhaust on and took off the cat it did not do it so maby check you cat may be done
Old Apr 6, 2005 | 06:20 AM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldGSR &raquo;</TD></TR><TR><TD CLASS="quote">Check out your spark plugs, wires, dizzy cap & rotor, and fuel filter. I was having the same problem and it turned out my plugs were gone, but it could be any of these things. Good luck!</TD></TR></TABLE>
I would definately look into this maintenance items first. They are cheap and essential for your car to run right.
CPreston
Feb 1, 2011 11:20 AM
milanocivic
Feb 20, 2009 08:26 PM
kelviiv
Sep 16, 2008 03:58 PM
BaNned
Jun 24, 2004 10:15 AM
Hapa88
Apr 23, 2003 10:45 AM
