Installed Short Shifter and Bushings
Old Jan 28, 2002 | 07:04 AM
mafioso102's Avatar
New User
Default Installed Short Shifter and Bushings
I jus installed an obx short shifter and energy suspension bushings. I notice the shorter throw, but there is a lot of resistance to each shift. You really have to jam it into gear. Is this because of the shift stabilizer i changed for the energy suspension one? Has anyone else experienced this?
[Modified by mafioso102, 4:04 PM 1/28/2002]
[Modified by mafioso102, 4:05 PM 1/28/2002]
Old Jan 28, 2002 | 08:52 AM
keithv's Avatar
Default Re: Installed Short Shifter and Bushings (mafioso102)
short shifters make the shifts a bit harder since you have moved the lever point higher. this effectively gives you less leverage for shifts.
the bushing kit will firm things up a bit as well. its probably just a culmination of things.
...but you shouldnt have to jam it in gear. that doesnt sound right...
you sure its just not notchy???
Old Jan 30, 2002 | 02:29 PM
606zc's Avatar
New User
I experienced the same thing when I replaced my shifter and bushings...the way i solved this problem was to loosen that bolt that goes through your shifter and bushings...
keep in mind though...
1) too loose will give you a sloppy feeling shift
2) too tight will make it tough to shift
so you have to do a little trial and error to figure what feels best for you...good luck
Old Jan 31, 2002 | 04:38 AM
keithv's Avatar
Default Re: Installed Short Shifter and Bushings (606zc)
good point 606zc as that probably is the problem. i totally forgot about that bolt...
DOUBLExDEUCEx22
Jul 8, 2009 02:12 PM
DOUBLExDEUCEx22
Oct 25, 2008 09:44 AM
96electronH
31
Nov 19, 2007 07:31 PM
jacoop86
10
May 23, 2006 11:53 AM
JDMKid71
May 10, 2005 06:41 PM
