Suspension & Brakes Theory, alignment, spring rates....
hear bad rubbing and steering wheel shakes?
Old Apr 5, 2005 | 02:46 PM
vizsual00's Avatar
Default hear bad rubbing and steering wheel shakes?
After installing my coilovers ( omni full setup) i started to hear a bad rubbing coming from my driverside and its not the tire. I lowered the car about 2in in the front. The sound or the vibration is not there when i first start driving but after about 2 mins you can hear it and it get progressively worse. The sound/vibration is worst when i let the car coast. when i brake it seems that they both stop. Could this be my axles? thanks in advance.
Old Apr 5, 2005 | 03:39 PM
RineRacing's Avatar
Default Re: hear bad rubbing and steering wheel shakes? (vizsual00)
I'll guess... loose lug nuts.
Old Apr 5, 2005 | 04:28 PM
vizsual00's Avatar
Default Re: hear bad rubbing and steering wheel shakes? (RineRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RineRacing &raquo;</TD></TR><TR><TD CLASS="quote">I'll guess... loose lug nuts.</TD></TR></TABLE>
after raising the car and not finding anything i think that was the prob. I tightened everthing again and rechecked and the problem seemed to dissapear. for me for being careless on the install.
Old Apr 5, 2005 | 04:58 PM
Tyson's Avatar
gee, howd you know???
i would have agreed!
Old Apr 6, 2005 | 10:51 AM
RineRacing's Avatar
Default Re: hear bad rubbing and steering wheel shakes? (Tyson)
When installing coilovers there are only a few parts of the car you touch. Wheels, LCA, shock and spring. Vibrations come from rotating parts. Neither the LCA, shock or spring rotates. Also, the vibration goes away when the brakes are applied so that narrows down where to look. Logic implies something in the Wheel/hub area is loose and rotating, i.e. the wheel.
It also happens that in the billion or so times I have changed wheels on my car I might have forgotten to torque the lugs once.
thekeysarebroke
Feb 18, 2013 12:42 PM
hell_sol
May 20, 2010 12:27 AM
SilverDc2
Honda S2000
Oct 16, 2006 08:11 AM
jaystar
Suspension & Brakes
May 13, 2006 07:24 PM
98cwtypeR
Apr 25, 2004 04:52 PM
