Knock Sensor.....
Old Apr 5, 2005 | 08:36 AM
LSEGHATCH's Avatar
Default Knock Sensor.....
I've tried searching but have come up empty handed trying to find out about a knock sensor and what roll it plays in swaps. Are there alternatives to this, I saw that someone posted a pick of a PLX device in another post about "knock sensors". I mianly wanna know what it does and why its needed.
Thanks
Old Apr 5, 2005 | 09:16 AM
EE_Chris's Avatar
Default Re: Knock Sensor..... (LSEGHATCH)
Try searching Google then.
Knock sensors play a role in engine management, not just Honda swaps.
Its basically a microphone that listens for detonation. If it hears it, the ECU will in turn pull timing in an attempt to stop the detonation.
Old Apr 5, 2005 | 11:24 AM
LSEGHATCH's Avatar
Default Re: Knock Sensor..... (EE_Chris)
So in doing my swap, I am going to have to install a knock sensor right or can I just go w/ the PLX R-500 which someone posted on this thread....?
https://honda-tech.com/zerothread?id=1197496
Old Apr 5, 2005 | 11:29 AM
EE_Chris's Avatar
If the swap you're doing comes with an ECU that is looking for a knock sensor, then yes, you need a knock sensor.
The PLX R-500 has nothing to do with a swap.
Old Apr 5, 2005 | 03:07 PM
Jmunk's Avatar
Mine was broke on my swap so i got a chipped ecu that didn't look for it, and it runs great. I just run 93 gas now, and i set my timing to 16 degrees.
memphosfinest
Mar 13, 2008 12:48 PM
KURUPTinc
Mar 10, 2008 10:26 PM
1.5boosted
Dec 14, 2007 01:45 PM
92ludeport
Jul 8, 2005 02:08 PM
G3gsr
Apr 27, 2003 04:54 AM
