Will CTR piston fit in my b20/vtec?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elegiono »</TD></TR><TR><TD CLASS="quote">i was wondering if CTR pistons fit directly in my b20</TD></TR></TABLE>
No. Think about it. The bore is larger then the standard 81mm. Even the oversized 81.25mm wouldn't even begin to fit an 84mm bore.
i think this topic has already been covered..
try doing a search.. (heres a link for you) ..
https://honda-tech.com/zerothread?id=1034244
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1600cc »</TD></TR><TR><TD CLASS="quote">resleeve it down to 81mm.
or
get a b18 block, b20 crank and rods. then you can use your ctr piston </TD></TR></TABLE>
or just get a b18a/b block that already has the same crank/rods as a b20 with an 81mm bore
or
