car burning oil?
Old Apr 4, 2005 | 03:24 PM
KingJeff's Avatar
Default car burning oil?
What could the problem be? It seems like my car is burning 4 quarts every month. One thing I have noticed is my bumper turning black right above the exhaust.
Old Apr 4, 2005 | 03:37 PM
PLAGUED_DB7's Avatar
Default Re: car burning oil? (KingJeff)
2 things really..Valves arent sealing or Piston rings really worn and allowing alot of blow by...what the mileage? How about the condition of spark plugs?
Get a valve adjustment and a leakdown test...that will give you results too.
Old Apr 4, 2005 | 05:41 PM
g2tegracer's Avatar
Is it burning or leaking?
Do you see smoke coming out of the exhaust? If so, under what condition? Do you ever see drops of oil under your car after it has been sitting over night or something?
4 quarts in a month is a LOT. Would be better if you could give it in mileage though since some people might drive 100 miles in a month and some people might drive 3000.
Old Apr 4, 2005 | 08:36 PM
KingJeff's Avatar
Default Re: car burning oil? (g2tegracer)
not sure if its leaking or burning. I think its burning. I have 191,000 miles
Old Apr 4, 2005 | 08:45 PM
whiteJDMdc2's Avatar
i believe he was asking more of how many miles do you drive a month..... 191,000 is alot of miles though if nothing has ever been done to your mottor and it has been driven had most of those 191,000 miles im sure your engine is ready for a nice overhaul... im sure like was said before your main problem is probably the piston rings letting a lil oil by into the combustion chamber
Old Apr 4, 2005 | 09:11 PM
KingJeff's Avatar
Default Re: (whiteJDMdc2)
I dont drive a lot of miles per month. Id say average. Maybe around 1000. I bought the car with 140,000. Got the timing belt, water pump, done not too long ago. HOw much u guys think itll cost to replace the piston rings?
Old Apr 4, 2005 | 09:16 PM
depends on where you ahve it done and with what kind of parts really.... i would say somewhere between 500 and 1000 for good quality parts and labor unless you can do it yourself or have a hook up
Old Apr 7, 2005 | 11:50 AM
KingJeff's Avatar
dam...that sounds expensive...might as well find a used ls motor.
Old Apr 7, 2005 | 12:23 PM
teggytegteg's Avatar
my da9 is doin the same thing...i figured it was the valve seals because i did a compression test and i got normal results.
so i calculated this: for a shop to repace my valve seals(i cant do it myself since this is my only car...no time..at the moment), it will cost around 400 bucks...****...jus to replace that....**** no...
i decided it is cheaper to buy a rebuilt head...and the motor...i will leave it that way(highmileage and ready to break at any moment) since i have a b16 laying around and waiting for some attention...
Old Apr 10, 2005 | 03:11 PM
KingJeff's Avatar
Default Re: car burning oil? (PLAGUEDDB7)
still not sure what the problem is but changed the plugs today. They were in bad condition.
zach1288
27
Nov 16, 2007 03:51 AM
EF9 JAMS!!!
Oct 7, 2006 12:37 PM
mikeSONICGSR
Jun 16, 2002 10:48 PM
MrSmith
Feb 13, 2002 03:50 PM
RedRacerCivic
Jan 26, 2002 01:32 AM
