90 Integra not starting, why?
My car was running fine but later on when i tried to start it it would not turn over
It is:
-Getting Gas
-Getting Spark
-No blown fuses
-I spray starter fluid but it does not ignite
-Starter is turning over but not firing the motor
If there is too much oil in a motor, can that stop it from starting. What can it be? Thanks
It is:
-Getting Gas
-Getting Spark
-No blown fuses
where are u getting spark? is it a good spark or is it weak, distributors go bad all the time. it depends on how over full u are with oil, and how cold it is, it will usually just cause a slow crank tho.
at 3am, i went out and tried to start it, it didn't completely start but it was close and when i let off the key, the motor kept somewhat running, it seems the longer i wait the closer it gets to starting. Any ideas?
my buddy is having the same problem.....we took off the fuel rail and injectors and they were not spraying.....so i would check that, also check fuel pump....it was what was wrong with my friends b20z motor. they go out all the time.....
szczerbanator
Jun 26, 2009 09:07 AM
fwdftw
52
Sep 5, 2006 11:31 PM
