Tach doesn't read correctly after b18c install.
Old Apr 4, 2005 | 01:13 PM
Sean Juan's Avatar
Default Tach doesn't read correctly after b18c install.
I have a b18c in an ej1 and used the z6 harness. It SHOWS vtec kicks in around 4k. The motor revs to 6800 in some gears, 7k in the others. However, it reachs 120 in 4th and it's at 7k. Therefore, I think it's revving out like it should (to 8200rpms), but the tach just doesn't read up to 8200 like it should. Instead it seems like its spaced out between 0 & 7000 rpms. What would be causing this?
Old Apr 4, 2005 | 02:34 PM
Sean Juan's Avatar
Default Re: Tach doesn't read correctly after b18c install. (GRIP KING)
ttt
Old Apr 4, 2005 | 03:28 PM
h22_cx_hatch's Avatar
there is this sensor that connects to the engine to tell you on the gauges the rpm and mph. i forget the name but this is probably what is causing your rpm problem
Old Apr 4, 2005 | 05:05 PM
Sean Juan's Avatar
Default Re: Tach doesn't read correctly after b18c install. (h22prludez)
yea it should be on the trans i was told. i think ill check it out.
Old Apr 4, 2005 | 06:23 PM
PrettyLude's Avatar
the vehicle speed sensor
Old Apr 4, 2005 | 10:14 PM
Sean Juan's Avatar
Default Re: (PrettyLude)
speedos' right tho. god iono whats goin on!! lol i think ill just live with the tach being off and memorize my different redlines for each gear lol.
crxricer66
Jun 18, 2008 01:09 PM
stealth89hatch
13
Jun 17, 2005 03:25 PM
WhiteGSR95
Mar 29, 2005 08:11 AM
esca
Dec 12, 2004 05:03 PM
Chemicalviper
Oct 21, 2003 10:23 PM
