Not Valve Noises?
Old Apr 4, 2005 | 08:31 AM
wragen22's Avatar
Default Not Valve Noises?
I went and got my valves adjusted at the dealership for $116. However I noticed the noise was still there this morning when I went for a drive and is still there. Any suggestions on what I should do next? My father and I thought for sure it was the valves.
Maybe its just the injectors like alotawatts said.
Old Apr 4, 2005 | 12:34 PM
GqchYnAbOy's Avatar
I have the same problem, adjusted the valves and can hear some sligh tapping sometimes..
Old Apr 4, 2005 | 12:44 PM
JonnySBeee...'s Avatar
Default Re: Not Valve Noises? (wragen22)
injectors....or rocker arms
Old Apr 4, 2005 | 12:55 PM
Elvis1977's Avatar
Default Re: (GqchYnAbOy)
Does the tapping go away after the engine warms up? Is so, then this is normal for a honda motor. Just let your car warm up well in the mornings. If you still hear tapping after engine is warm then valves could be the problem. You can only adjust valves correctly when the engine is STONE cold!
Old Apr 4, 2005 | 04:37 PM
wragen22's Avatar
The sound is only really loud in the mornings. After it is warmed up it is very hard to hear. I dropped off my car at the dealership overnight so they could adjust next day after sitting. I really don't want to bring it back to the dealership. Maybe its just normal. Its just really loud in the mornings...
Old Apr 5, 2005 | 06:00 AM
Elvis1977's Avatar
Default Re: (wragen22)
The tapping in the mornings is NORMAL for honda engines. How many miles are on your 4-cyl.? Toyota motors are much quieter in the mornings.
Old Apr 5, 2005 | 06:49 AM
90accorddx's Avatar
try running a higher octane gas that will usually take care of valvtrain noise
Old Apr 5, 2005 | 11:43 AM
wragen22's Avatar
I currently have only 40k miles on it. :-) What octane gas would be good? I'm also thinking about switching over to synthetic oil.
Old Apr 5, 2005 | 03:00 PM
YeuEmMaiMai's Avatar
running higher octane gas in any accord prior to 7th gen is a waste as the ECU cannot compensate for the higher octane and your engine performance may end up being less.
C&D did a octane test on the 6th gen v6 car and the HP dropped about 7 or 10PH (I cannot remember the exact #) when the switched to 91 octane.
Old Apr 8, 2005 | 08:15 AM
wragen22's Avatar
Its kinda weird that even after my valve adjustment I still have a noise in the mornings, or after a long sit.
Old Apr 8, 2005 | 10:32 AM
Elvis1977's Avatar
Normal for Honda. Yeh, it also bothers me in the mornings. Just let it warm up well before you drive. Or, get a Toyota and see how much quieter the engine is in the mornings.
Old Apr 8, 2005 | 11:44 AM
wragen22's Avatar
Are toyota's really quiet in the mornings? I wouldn't switch...I'm too happy with my accord.
jmai86
Apr 1, 2008 12:10 PM
Peruviann83
Mar 30, 2007 10:10 AM
davidnguyen
Nov 8, 2004 08:09 PM
Flux
Apr 15, 2004 07:25 PM
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
