Why are so many people doing 92 DX MPFI swap in their CRX DX?
Old Jan 27, 2002 | 08:47 PM
Jaysmy's Avatar
Default Why are so many people doing 92 DX MPFI swap in their CRX DX?
I am a newbie in this kind of thing so please enlight me. Does it make more sense to put in 89-91 CRX Si MPFI? Please correct me if I am wrong. Is there any website I can read up on all of these techies knowledges? Thanks again.
[Modified by Jaysmy, 9:49 PM 1/27/2002]
Old Jan 27, 2002 | 08:58 PM
Aphrodavid's Avatar
Default Re: Why are so many people doing 92 DX MPFI swap in their CRX DX? (Jaysmy)
theres no site that i know of that goes into specifics about the swap or anything. i have a 90 DX HB and i did the MPFI swap with a 92 DX FI system. its a proven fact that 5th gen(92-95) FI systems flow better than 4th gen(88-91) FI systems.
Old Jan 28, 2002 | 04:16 AM
Mista Bone's Avatar
D Tranny Guru
Doing the 88-91 MPFI upgrade on the 88-91 DX motors is a 12-14 HP upgrade.
FYI the 92-95 DX intake manifold has the same size/shape runners as the 88-91 Si/EX's.
Respect the 1.5's, else your B16 might get beat.
Old Jan 28, 2002 | 12:08 PM
AbaZ's Avatar
Default Re: Why are so many people doing 92 DX MPFI swap in their CRX DX? (Mista Bone)
I think 12-14hp is a bit off.. You are looking more around 5-8hp
If you plan on upgrading the cam also, you might get the extra 3-4hp.. I do lots of work with d15's and d16's and they are great little motors. I couldnt imagine running the DPFI setup, but I know a guy who is running a turbo on his d15 DPFI setup, check out my website.
D15b2 92hp
D16a6 108hp
Jeff
[Modified by AbaZ, 9:09 PM 1/28/2002]
Old Jan 28, 2002 | 12:18 PM
MIDNIGHT's Avatar
Default Re: Why are so many people doing 92 DX MPFI swap in their CRX DX? (AbaZ)
mista i got another ?. i am going to swap in a lsvtec for waffles and i want to do some thing to his cx motor. this is my plan.
cx motor
98 non vtec head from a dx
89 teg pistons
stock cx intake manifold
zc/si tranny
in a 90 hatch
should i change anything? i have a d16a6 cam is it better than the y7(?) stock cam?
its just a auto x car. so low in is what i want from it. TIA.
Old Jan 28, 2002 | 02:00 PM
Mista Bone's Avatar
D Tranny Guru
D15B7 = 102 hp
D15B2 = 92 hp
ONly cjange what the intake manifold to a 88-91 Si size and TB had newer bolt pattern.
Old Jan 28, 2002 | 02:16 PM
AbaZ's Avatar
I just measured a 89 dx cam vs a 95 dx cam both 1.5l. The Newer cam has a slightly larger lift then the older dx cam.. this is probably where the extra HP is acheived.. I will find a d16a6 cam and measure it to see if its the same as a d15b7 cam..
Jeff
Old Jan 28, 2002 | 02:18 PM
Aphrodavid's Avatar
i can already tell you that the D16a6 cam is different than the D15b2 cam.
Old Jan 29, 2002 | 05:52 AM
Mista Bone's Avatar
D Tranny Guru
AbaZ, show your measurments.
I wish to concur the findings
Old Jan 30, 2002 | 12:11 PM
SiR Kid's Avatar
New User
let's not forget that the 88-91 d15 DX engine is .6 more comression than the d16a6... I think tha tthat alone MORE than makes up for the .1 liters more displacement.
I say the 1.5L with the Si cam, Si intake manifold and throttle body would make 110-115 hp just shooting from the hip.
Old Jan 30, 2002 | 12:55 PM
CRzex's Avatar
New User
Default Re: Why are so many people doing 92 DX MPFI swap in their CRX DX? (SiR Kid)
Wait so you can swap a 92-95 dx mpfi system with a 88-91??? Cuz right now i have a DX and im still running with the DPFI and i was planning to convert it to MPFI using the 88-91 fi system, so would swaping the 92-95 dx mpfi system be the same as swaping the 88-91 fi system. Does anyone have any info on this?
TIA
Old Feb 2, 2002 | 05:53 PM
OldGeezer's Avatar
Please help me simplify my shopping list.
In order to upgrade my '89 DX 1.5 DPFI to an MPFI system, would I be correct in seeking the following parts:
88-91 Si intake and throttle body OR 92-95 intake and throttle body
AND
Several member replies have suggested a cam upgrade...again, would I be correct in seeking the following parts:
88-91 Si camshaft OR is there another source, besides aftermarket jobbers, for such an upgrade?
Thanks!
Old Feb 2, 2002 | 07:31 PM
Mugen Dom's Avatar
Default Re: Why are so many people doing 92 DX MPFI swap in their CRX DX? (OldGeezer)
ull need the whole intake manifold and tb plus a dist and injecter resister box and ecu pm6
the 88 cams are all the same so leave that out 89-91 si perferably a 91 it may be slightly different so ive heard but u dont need to upgrade really its an easy swap i made an entire post on how to do it do a seach for mpfi directions it should come up
Old Feb 3, 2002 | 09:39 AM
Lt. Dan's Avatar
Default Re: Why are so many people doing 92 DX MPFI swap in their CRX DX? (jdmB18hatch)
So, does anybody know if there is any benefit to swapping the 92 DX manifold onto a CRX Si?
Dan
Old Feb 4, 2002 | 04:00 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Why are so many people doing 92 DX MPFI swap in their CRX DX? (Lt. Dan)
no benefits. The CRX Si and 92-95 DX manifolds have the same ports and runners.
Just the TB mount pattern is different. Maybe some of the emission crap issues also.
Old Feb 4, 2002 | 05:10 AM
TypeR0207's Avatar
I put a 2000 DX head on my D15B1 ..... just because I got it for $85.
With that and the Si MPFI swap (and an intake and cheap header), my STD is a completely different beast.
I can actually pass in 4th when I couldn't before!! (Only have a 4 spd).
But I know what a B series can do ... so that is high on my shopping list!! The MPFI swap was just a step to a goal.
low_crx87
Sep 11, 2005 10:25 PM
TorganFM.
Apr 10, 2004 06:55 PM
justinau
19
Apr 5, 2004 06:38 PM
TONEBONE
Jul 22, 2002 06:29 AM
hfracer420
Feb 12, 2002 07:54 AM
